Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Painting
  1. #21
    Apr 2005
    should be okay if you sand it with 200 or 400 grit before you primer it, be it metal or plastic. i have a plastic trim and it stuck fine, i don't know if you have metal trim, but it should work the same.
  2. #22
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    as scottfx said. If you are using the vinyl paint, sand the item first. Use 600 or 800 wet and dry with water. Give it all a light sand. Then clean it with wax and grease remover to get rid of any crap on the item so the paint can adhere. Also paint in very light coats. REMEMBER surface prep is the key
    It take longer, but it won't come off. I have just finished painting my radio surround. No photos yet put I will post them if you want when it's completely finished.
    I believe the duplicolor now has a vinyl primer that you can now use any of their normal car colours over the top.
  3. #23
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    also don't waste your time using anything above 600 grit unless you are going for an automotive finish, and still you'd only be using those on your top coats, not your primer. I would take sickvette's suggestion and use the epoxy high fill primer for best results. Lastly let the paint cure for a day or two before you install it, especially if you use a vinyl paint. oh...and lastly (again) make sure your surface is clean, i use mineral spirits and don't touch the piece with your bare hand after you clean it. use some latex gloves, (you know like the kind that you use on friday nights with the boys j/k) while painting and handling the piece....
    this doesn't apply to you but for those going for the automotive finish, when you wetsand, make sure to use a drop or two of dish soap in the water that you're using to dip the sandpaper in.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  4. #24
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    Quote Originally Posted by 0l33l
    Mobile-Effects: Access Denied
    sign up you lazy sack of
  5. #25
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I visited Kragen today. I found a lot of paint that said for use on trim, but none was specified as "trim paint"
    Is that the same thing
    Also which primer is best out of these? http://www.duplicolor.com/products/primer.html
  6. #26
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I picked mine up at discount auto parts
    comes in a bunch of colors, I also used the duplicolor approved primer, because it will lift normal primers
    but it took about a day for the final coat to dry completly
    oh yeah and I used the filler primer
    肚子笑痛了
    S60 Install
  7. #27
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by jcdillin
    ok about the primer. I actually saw it for sale today. But about the paint: i didn't find any paint that looked like this:
    But I saw a ****load of these paints. The small tet says also for trim
  8. #28
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Yeah..... that is the trim paint from duplicolor (the one with the mirror on it)
    go to autozone or other autoparts don't be lazy
    Edit:
    here is a link with the part # from AdvanceAutoParts
    http://www.partsamerica.com/ProductD...artnumber=TP70
  9. #29
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    If you really need something that durable get a true catalyzed urethane sprayed on such as Sikkens Rallye Black. Anything out of a can is going to be softer but a commercial brand like SEM will be as good as it gets.
    Fabricator
  10. #30
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by thanatos106
    Edit:
    I guess I'll go to autozone next
    Quote Originally Posted by Altimat
    I guess you recommend SEM trim paint. Correct?
  1. Help With Sanding and Painting Interior Plastic
    By xhazn in forum Fabrication
    Last Post: 05-06-2005, 07:18 AM
  2. when painting dash trim does paint flack easy?
    By sr_ryan1 in forum Fabrication
    Last Post: 10-09-2004, 09:28 AM
  3. Painting a reverse / parking sensor?
    By modemide in forum General Hardware Discussion
    Last Post: 09-06-2004, 08:05 PM
  4. Replies: 8
    Last Post: 09-02-2004, 03:24 PM
  5. I'm painting my truck a perty color
    By lstrunk in forum Off Topic
    Last Post: 03-31-2002, 09:39 PM
