Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Smooth Factory Finish
  1. #11
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Quote Originally Posted by Altimat
    You usually want a semi-flat or flat finish on interior parts so I use neither.
    What kind of block you recomend??? I when back to the place where I got the evercoat filler and bought one (the have three kinds...I end buying the soft one) it cos $3 bucks so if I got the wrong one I just get the right one..
    Thanks altimat
  2. #12
    Nov 2004
    Pic #2
  3. #13
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Altimat is correct.....NO LIQUIDS ON BODY FILLER. If you want a piece to have a glass like surface you need to use a high fill primer and sand that. I sand all my body filler with 80 grit and stop there. A few coats of primer and it is perfect. If you are looking for a factory finish there are paints available for that. I still prime my pieces and then apply the paint. If you want a high gloss finish the clear coat will be needed and depending on how well the clear coats lays out you might need to wet sand and buff.
    thanatos....that is an excellent sanding pad. I buy those a dozen at a time. You can purchase rolls of sticky backed sand paper to apply to it or wrap a piece around it but the sticky works better. If you are not going to use the pad for a while remove the paper when you are finished with it. Paper left on the pad can detoriate and leve residure behind if left on the pad too long.
  4. #14
    Nov 2004
    Thanks for the info sickvette.
  5. #15
    Jun 2005
    cool guys.. took your advice.. it match completly perfect to the exsisting interior. texture and all.. will post pics when I get a chance
  6. #16
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I make custom blocks for almost everything. I have cut up several of those into different sized blocks, but I prefer harder blocks for most work. Pieces of paint strring sticks work well on this little stuff. Those small 6" stainless rulers work well sanding up into tight corners with self-adhesive paper on them too. I even use pieces of hacksaw blades as bondo files.
    Fabricator
  7. #17
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    this is why I idolize you...
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
  1. Installing computer w/ 2000 GM factory stereo-how to connect
    By SpkTheD in forum General Hardware Discussion
    Last Post: 05-09-2005, 08:05 PM
  2. Factory Amplifier In Mercedes C-Class
    By Eiknujrac in forum Newbie
    Last Post: 03-13-2005, 09:05 PM
  3. Replies: 3
    Last Post: 12-03-2004, 04:51 PM
  4. Factory controls
    By cruiser01 in forum Input Devices
    Last Post: 09-22-2004, 02:40 PM
  5. Can a factory alarm command the OPUS to power down?
    By The Grinch in forum Power Supplies
    Last Post: 07-10-2004, 12:13 PM
