Results 1 to 10 of 17
Thread: Smooth Factory Finish
    Jun 2005
    Just wondering how you guys get a perfect smooth finish with bondo.
    What i Did was install my LCD but i had to cut out the cigarette lighter,
    and the ash tray.
    So now I have an empty space. Well I started filling in the holes, by making a frame (out of cd jewel case parts) then used epoxy to get it in place and mount. then I started filling in the holes with Bondo, (tons of it). it is pretty much level, but still wavey ( not even everywhere) so I used some glazing putty. btw. I have sanded a ton to try and get it smooth. just seems like it never gets anywhere.
    It helped even it out a bit, but i think that if I spray paint it, it will still look a bit wavy and not smooth.
    What do you guys recommend..?
    FLAC Chairboy's Avatar
    Jan 2004
    sand, smooth, sand, smooth, sand, smooth, rinse repeat.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    pics would help but mostly u need a sanding block and alot of time
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    How many hours did you put into it?
    Like the rest said... sand and use progressivly less course sanding paper.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Always use a block.
    Fabricator
    Jun 2005
    I've put like 2-3 days into this thing, and it's not very big. it's like a little widder than a dvd case and half the height.
    But I guess I will just keep going.
    Thanks guys
    Constant Bitrate FociMan's Avatar
    Jun 2005
    Gloucestershire
    I find wet n dry sandpaper at a courseness of 1200 seems to do well with plenty of water. Wet sanding is the key IMHO.
    FociMan
    Ford Focus Collection
    EPIA M10K / 512Kb / Creative Audigy NX USB
    8" touchscreen
    D-Link USB Radio
    USB GPS Mouse
    Bluetooth GPRS Web Connection
    Centrafuse Beta2 / MapMonkey
    Oct 2003
    WI
    1200 is waaaay too fine for bondo. That is a grit that might be used for color-sanding paint prior to polishing. I don't go finer than 180-320 with bondo. Wet-sanding is also not recommended with bondo. It absorbs water like a sponge and its possible to trap moisture in the filler which can cause problems with the topcoats later.
    Fabricator
    Jun 2005
    do you guys use polisher on your pieces after you have painted. or is some clear coat just as good...
    Oct 2003
    WI
    You usually want a semi-flat or flat finish on interior parts so I use neither.
    Fabricator
  1. Installing computer w/ 2000 GM factory stereo-how to connect
    By SpkTheD in forum General Hardware Discussion
    Last Post: 05-09-2005, 09:05 PM
  2. Factory Amplifier In Mercedes C-Class
    By Eiknujrac in forum Newbie
    Last Post: 03-13-2005, 10:05 PM
  3. Replies: 3
    Last Post: 12-03-2004, 05:51 PM
  4. Factory controls
    By cruiser01 in forum Input Devices
    Last Post: 09-22-2004, 03:40 PM
  5. Can a factory alarm command the OPUS to power down?
    By The Grinch in forum Power Supplies
    Last Post: 07-10-2004, 01:13 PM
