Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: bondo shrinking?
  1. #11
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    once again mista mike tha mastermind comes to the rescue :-D
  2. #12
    Jun 2005
    thanks good advice. This is my first project, but it's turning out really well. I will post pictures when I can. I don't have any before, but if you know what a acura vigor gs interior looks like then you know what I am dealing with.
  3. #13
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Bondo is not designed to applied thick or as an adhesive. Bondo is a surfacing agent...meaning it is meant to get a smooth surface with minimal effort. Bondo that is too thick can and will often shrink and crack. Bondo that is mixed too hot will shrink and crack. When building a project..any kind of project...the base material should be built up as much as possible so that only a think layer of body filler is needed to bring it to a finished surface. Also do not use any kind of liquid on body filler. The filler will absorb the liquid and then release it later as it gets hot and evaporates. Only clean bondo with a tac cloth..once it is primed and sealed a degreaser or prepsol can be used.
  1. smoothly bonding metal and bondo?
    By Dexter in forum Fabrication
    Last Post: 03-12-2009, 11:54 AM
  2. I hate Bondo
    By djXternal in forum Fabrication
    Last Post: 05-14-2005, 02:25 PM
  3. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  4. Bondo won't Dry! Just Stays tacky!
    Last Post: 12-05-2004, 10:11 PM
  5. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
