Results 1 to 8 of 8
Thread: Framing an LCD...
    Newbie pikers's Avatar
    Jun 2005
    Framing an LCD...
    Hi all! Big noob here.
    Question though...What would you use to frame an LCD monitor. I have an Alpine TMEM580, and it's flush mounted where the ashtray and cig lighter used to be in an 03 Maxima. Looks good, but since the cuts aren't absolutely perfect, I would like to know what you could use to "frame" the monitor. I'd like the fit to look as factory as possible.
    Right now, I'm using that door bumper-trim stuff that goes on the edges of doors to prevent dings. Works OK, but the corners won't lay flat because of the 90 degree turn it makes around the corners.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hmmm thas kinda hard i would bust at it with some bondo take the cage and bondo that in and then all u do is slide in the headunit over it you need the stock trim piece tho!
    Jun 2005
    Quote Originally Posted by xdjxklusivex
    You mean the standard routine of removing the bezel, Bondoing that in, then reassembling the monitor?
    OK, but that also entails sanding, painting, etc. All I really need to do at this stage (since I'm not looking to add work to this project just yet) is to trim the edges of the cut in the plastic surrounding the monitor.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If you don't want to do a lot of work to get it right, then it will never look perfect.
    However, here's a ghetto trick that may work for you if the surrounding plastic is black. Use black electrical tape. Use an Xacto knife to cut the corners at a 45 degree angle and frame it like a picture.
    Want to:
    Dec 2004
    Halfass!!!
    ddn
    ddn is offline
    Dec 2004
    I have a similiar problem. My DennisK bare panel doesn't HAVE a trim piece to fab into the dash. How would you guys go about making a bezel piece absolutely from scratch?
    Jun 2005
    Quote Originally Posted by Bugbyte
    LOL! No, I don't want to go from hours of fabbing to electrical tape...Something tells me there's quite a few other options in between that others have tried. The 7" Alpine had a snap-on bezel; the 5.8 does not.
    Jun 2005
    Halfass!!!
    Have you contributed anything useful to any thread?
    Been reading an few others, and it seems you just trail onto other great ideas, like the short guy in the back of a crowd that screams his agreement with the guy in the front.
    Just curious.
  1. Precautions in wiring up an LCD?
    By Wild Violence in forum LCD/Display
    Last Post: 05-12-2004, 03:53 PM
  2. Character LCD in MediaCar
    By RagingTurkey in forum MediaCar
    Last Post: 04-22-2004, 05:09 AM
  3. Designing a double-din case for 2003 WRX
    By Giuliano in forum General Hardware Discussion
    Last Post: 03-26-2004, 11:19 PM
  4. WANTED: DEAD/BROKEN 7" LCD (All i need is the framing!!)
    By Shizank in forum Classified Archive
    Last Post: 03-16-2004, 12:14 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
