Results 1 to 9 of 9
Thread: TVIEW fab help
    Jan 2005
    TVIEW fab help
    The tview screen just simply pulls out from the front bezel. There is no screw or anything. How do you guys keep help to the bezel? Help please. And yes I searched!
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    your new friends name is hot glue :-D
    Mar 2005
    Ohio
    I used a T-view. I just made up some little metal brackets that basically just press the screen against the bezel. Works pretty well.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    I just put the back on and glued it shut, works pretty good!
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Variable Bitrate UM_Fan's Avatar
    Feb 2005
    Miami, Florida. 305
    I just put it back together and added a small fan n the back
    Crazy Miami Drivers
    R.I.P. My first ever NEW Car
    Old installation
    New Install!!!
    |-------------------100%|Cables ran
    |----------------85%----|Software RR
    |--------------80%------|Complete
    [/SIZE]
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    Quote Originally Posted by xdjxklusivex
    not a good idea, everything i've ever done with hot glue in a car has melted and fallen apart. When I took my explorer down to SC, it was like 115 and my composite lcd (no carpc at the time) sunk back behind the enclosure i made for it.
    PC Components:
    My work log
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    I second the hot glue issue, I use it in my case to hold my mobo in, and my hard drive. Needless to say hot glue melts at a pretty low temp and will not work to well.
    Screws and brackets my freind. Use the head rest enclosure it came with as well. IT will look good, give you the ability to remove the screen (in case it dies or you upgrade) and will make life easier...maybe
    You can still have something if you have nothing
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    There are high temp hot melt glues.
    Fabricator
    Mar 2004
    no cover
    look at my photos the original case is unused
  1. nvidia setting for 800x480 on tview?
    By fuctup in forum LCD/Display
    Last Post: 03-05-2006, 05:15 PM
  2. TView Auto Power On
    By MoonShiner in forum LCD/Display
    Last Post: 06-10-2005, 06:43 PM
  3. Question about Tview monitor.
    By kingvitamin in forum LCD/Display
    Last Post: 04-26-2005, 09:56 PM
  4. tview Overheat
    By neon_eddy in forum LCD/Display
    Last Post: 03-14-2005, 10:39 PM
  5. lilliput or tview
    By lqqkqik in forum LCD/Display
    Last Post: 07-13-2004, 12:01 AM
