Results 1 to 7 of 7
Thread: fiberglassing trouble with resin
    Dec 2004
    Orlando, FL
    Okay, so ive been reading these forums and the some other sites on how to fiberglass. i went to the local lowes and bought everything. i cut out the circle 3/4 inch mdf board. i prep everything. i mixed up the harder and resin and then apply. the the problem that happened was i couldnt get the fiberglass mat to form around the edge of the circle. the resis harded in the bucket 3 minutes after mixing it up. the can's direction was 14 drops per once. that seemed kinda high to me, but in some of the threads ive read this is not high at all. what can i do to make the fiberglass form around the edges of the wood better and how can i stop the resin from harding so quickly?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    still needa do alot more searching :-D
    u need a mold on the bottom to attach the circle to then you need to wrap it in fleece and put resen on the fleece then apply fiberglass over the fleece
    i cant believe you measured 14 drop to one once haha ive never measured!
    and if it gets hard too fast thin it out with acitone
    Dec 2004
    Orlando, FL
    What kind of fleece?
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    You can take a look at my project (in my signature), I have my fiberglassing project for my sub box described (it's not finieshed yet though)
    My mix take approx 10mins to harden, it gives me enough time to do a complete layer. Don't mix up too much of resin at the same time
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
    Feb 2005
    Oh and by the way, take a look at these tutorials
    http://web.njit.edu/~cas1383/proj/main/
    My Corolla Computer
    Dec 2004
    Quote Originally Posted by Sillydipstixs18
    100% polyester works best but u can use just normal thin cloth or shirt
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Humidity and operating temp effects how fast the resin will dry. Here in Florida it is so humid I put just a dab of hardner into everything so it will not kick off to fast.
    Saturation is the key to getting the matt to lay out. Cover the area with resin before applying the matt. The lay the matt in the already wet area. Then saturate the matt...it has to be very wet. All of your fiberglass should be so wet that it is nearly transparent and the color should be even across the work piece.
  1. Foam to use as a base in fiberglassing, bondo work, etc.
    By imprezive one in forum Fabrication
    Last Post: 10-04-2006, 11:26 AM
  2. Create an OBD Trouble Code?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-16-2005, 11:59 PM
  3. clay and fiberglassing
    By zerosiggls in forum Fabrication
    Last Post: 07-12-2004, 11:54 PM
  4. Disaster! aka, Adventures in Fiberglassing
    By Chairboy in forum General MP3Car Discussion
    Last Post: 04-12-2004, 02:02 AM
  5. Fiberglass resin questions
    By ddt in forum General MP3Car Discussion
    Last Post: 10-02-2002, 02:07 PM
