Results 1 to 10 of 11
Thread: On-dash fabrication
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    On-dash fabrication
    In effort to make my lcd look more "factory", I have been thinking of making an on-dash mount.
    Here is a rough photoshop...
    basically I would frame off the lcd with mdf, bondo the screen in, and then mdf for the sides.
    I don't have many wood working tools, and would probably more comfortable mounting the screen in something prefabbed. If anything comes to mind, let me know.
    How well does bondo cure on mdf? Is there an easier solution? I have thought about fiberglass.
    Generally, give me your ideas. Thanks
    Variable Bitrate anky1's Avatar
    Apr 2005
    NJ
    could you give a head on shot of the center console showing everything to work with?
    I may be able to give some ideas
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by anky1
    thanks, and here are more views i just took.
    I have seen an lcd mounted where the vents are, love it there, but i don't think i could drive with only one puney vent on the left of the steering collumn blowing cold air.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Search balsa-foam and buy a chunk of that big enough to work with. Then you can create a more OEM looking shape with rounded corners and glass the whole thing.
    Fabricator
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by Altimat
    balsa-foam seems a bit pricey.
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Why not dump the head unit and put it there, makes the most sense. Easiest to actually accomplish too...
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by sdashiki
    I like having the headunit, makes a nice backup. And the LCD there is too low.
    Aug 2004
    Floreeda
    Everyone says the same thing. But in your case Im not sure you have the luxury of keeping you HU where it is.
    if you want to keep it, why not move the HU instead to somewhere else.
    having the LCD up high where you want it invites all kind of trouble...too high, can be seen by other cars VERY easily, could be in the way of the drivers field of view, etc etc.
    how is having the LCD where the HU is, too low when you use your HU in the same position....
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    move ur headunit uptop and make the piece for the headunit insted of the screen and put the screen on the bottom it will look tighter
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    This is much much less work.
    -Install the LCD in that "double din?" space where the HU is. You can either us ABS melt method as discuss in in other thread or use the same material (SEM bumper repair)from the link below, and that is what I used for my Matrix Fab.
    -Move/relocate the HU down to where the cig lighter is follow this guy instruction how to fab the HU there. Saturn DVD installed
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Starting in dash fabrication
    By Cris in forum Fabrication
    Last Post: 08-23-2008, 02:54 PM
  2. Duramix is the Answer for Dash Fabrication!
    By johnram in forum Fabrication
    Last Post: 01-16-2008, 07:42 AM
  3. 3rd Time's the Charm??? Mercury Cougar Dash Lilliput
    By antimatter in forum Fabrication
    Last Post: 08-07-2006, 12:21 PM
  4. Dash Fabrication for Chevy Truck!
    By voidunknown in forum Fabrication
    Last Post: 04-06-2005, 07:31 PM
  5. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 10:51 AM
