Results 1 to 9 of 9
Thread: pics of dash, any help with design?
    Jun 2005
    Hey this is my fiat punto dash. Just wanted to know if it was possible to move the heater knobs somewhere else cos that would be the ideal place for the screen. the original position below the head unit is just a bit too low. tell me what you reckon?
    also another quick question, tried to find the answer myself. I'm taking the 8inch lilliput casing off so i can get it to look flush with the dash. after the case is off how does one change the inputs from vga to s video etc cos the buttons are on the front!?
    Feb 2004
    Victoria, Texas
    It really depends on how much work/time you are willing to put into it.
    Personally I like you second option best, mounting your screen up more. This gives you serveral advantages and won't be as distracting vs. having the screen lower. If you placed the screen in the lower position, it is going to be harder to switch songs and stay focused on the road.
    However, it takes more work moving you AC/heat controls and such. It will some time and a good amount of research.
    Also, the Lilliput should come with a remote that allows you to do the functions you need. Just don't cover up the IR sensor.
    cheers and good luck
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    I like the second option (dash3.jpg) also, but yeah, it's going to take the most work...
    If you want the easiest way, for for option 1. If you want it to be the best it can, go for option 2.
    Newbie simple's Avatar
    Jun 2005
    Manchester, England
    heres where i put my origional one, im currently re-doing it but u get the idea
    check my new dials too, awsome:
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    if the climate controls have no mechanic parts than relocate them lower.
    Jun 2005
    Manchester, England
    unfortunatly they do, but im sure its worth the sacrifice. thats what im planning anyway.
    Jun 2005
    simple did you actually put your screen there then or is that just done ont he computer to show what it would look like? im prob gonna go for option 2 like. I'll let you know how i'm getting on, give us some tips if you come across any too simple seeing as though we both have puntos!
    cheers for the help lads
    Jun 2005
    Manchester, England
    actually did it rich, got more photos of it too
    check this thread out: http://www.puntosports.co.uk/forums/...ad.php?t=16119
    my new install will be more like your option 2 though, but theirs quite a few things to concider when doing so, so be carefull with it and itll look awsome just bought a touch screen to go in and some carputer bits
    Jun 2005
    looks really good simple. Just started moving the bits around now, should be ok, but itll take some time. Could you tell me what type of filler u used around the screen, and where u got your bracket and what type u used to hold the screen to the dash.
    cheers
  1. 3rd Time's the Charm??? Mercury Cougar Dash Lilliput
    By antimatter in forum Fabrication
    Last Post: 08-07-2006, 12:21 PM
  2. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 04:47 PM
  3. trying to mould dash.... pls advise...
    By CA 3000GT in forum Fabrication
    Last Post: 06-07-2005, 05:51 PM
  4. Sanding dash, need help!
    By mazda3uzr in forum Fabrication
    Last Post: 12-22-2004, 05:27 PM
  5. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 05:18 PM
