Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 100% ABS LCD install with texture
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Figured i'd post this here to help anyone interested in molding their LCD into their dash using only ABS plastic, since it won't crack due to temperature variations, and different expansion of dissimilar materials (ex: bondo over ABS, etc.)
    First, I bought some 12"x12" ABS sheets from Mcmaster.com:
    then I cut a sheet so it fits in the dash:
    Then ripped apart my Lilliput 8", and cut off the lower part with buttons using a jigsaw:
    Then sanded the paint off the Lilliput bezel to get my ABS goo
    which i'm using to weld all my ABS pieces together.
    Then I glued the Lilliput bezel to the ABS plate after cutting out a spot for it:
    Backside (detail of ABS goo):
    Then I sprayed it with Duplicolor's Adhesion Promoter for plastics (available at auto parts stores), then a light coat of SEM texture spray to get a pebble grained texture:
    Then another coat of adhesion promoter, and two coats of Duplicolor Bumper Coating (black):
    The other piece is a trim piece i built up using ABS plastic strips, and sanded to shape. Here are several pics during it's build:
    And finally the whole assembly installed:
    Worklog is posted Here
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Oct 2004
    NY
    I like that old RF symmetry setup.......they were awsome & the first of it's kind.....do you have the 32 band eq add in board?
    what is the part # for that sem texture coating? I can almost make it out in your photo, but not complete.......I would like to play with it.....
    screen install looks great btw....
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    Very awesome, love the overhang to help with the sunlight.
    2000 Sunfire build 100%, or is it ever really 100%?
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by turbocad6
    I have the 28 band eq module installed... Here's a link for the texture spray: http://shop.store.yahoo.com/yourauto...e/semteco.html
    WORKLOG
    Webpage
    Oct 2004
    NY
    oh yeah, 28 band....it's been a while, but I used these in a few installs...., thanks for the link...
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    coool man, nice to see you back.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Jul 2005
    awesome man. good job. do you have the exact part number of the abs sheets you ordered off of Mcmaster.com?
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by n_pertuset
    Go to http://www.mcmaster.com/ and in the search box, type in "ABS sheets", or the part #. They carry several thicknesses and sizes. I think the part # is 8586K162. I bought two 12" x 12" 1/8" thick sheets. After shipping to FL it cost me $17.
    WORKLOG
    Webpage
    Jul 2005
    Lindenwold, NJ
    I too would like to thank you for the ABS supplier hook up. Good stuff, and I like the install. Looks really clean. This ABS "goo" you are talking about.... Is that a product or are you using ABS glue or some sort of putty ABS mix combo to make a "goo"?
    Raw Wave tj!2k4's Avatar
    Oct 2004
  1. Extending your laptop's LCD cable: FAQ
    By Yuriy in forum LCD/Display
    Last Post: 11-25-2008, 03:06 PM
  2. Replies: 14
    Last Post: 12-09-2005, 04:03 PM
  3. graphic LCD or PSOne LCD
    By hannibal in forum LCD/Display
    Last Post: 09-26-2004, 09:40 PM
  4. LCD install idea.....
    By cruzc_99 in forum General Hardware Discussion
    Last Post: 09-28-2001, 06:03 PM
  5. Preview of my in Dash LCD install
    By Destin in forum General MP3Car Discussion
    Last Post: 01-27-2001, 11:48 AM
