Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: What do i use to bond PP plastic and Xenarc case?
  1. #11
    Jun 2005
    Any chance you giving us the products name and number and where in Home Depot we can find it?
    Quote Originally Posted by oekundar
    HEre's what I used...at Home Depot, they have this Expoxy that hardens into a plastic . It is workable up to 60 minutes so you can take your time and fully cures in 12 hrs or so...and it was on ly like $3 or so...
  2. #12
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    Use hot glue to set it
    then fill with bondo glass
  3. #13
    Jul 2004
    Quote Originally Posted by kevin300z
    i will get that for you tonight..
    http://memimage.cardomain.net/member_images/2/web/170000-170999/170063_221.jpg
  4. #14
    FLAC evandude's Avatar
    Mar 2005
    Maine
    you could try this stuff, which I think they carry at home depot.
    it is basically epoxy with some plastic solvent in it, so it dissolves the plastic a bit so the epoxy can solidly bond to it.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  5. #15
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    evandude is exactly right! That is what I used for mine and it worked great!
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
  6. #16
    Jul 2004
    It is called PC.7 Epoxy Paste. Made by Protective Coating Co. www.pcepoxy.com for more info
  7. #17
    Jun 2005
    If I had to do a big area, would it work if I used a base of fiberglass then for the finishing work to use this over it so it would never crack?
  1. Cubid 2699 case with 3.5" HD plus PCI ???
    By markbuts3 in forum General Hardware Discussion
    Last Post: 05-27-2005, 11:20 AM
  2. Replies: 5
    Last Post: 03-31-2005, 02:07 PM
  3. Yet another xenarc convert...
    By silencery in forum LCD/Display
    Last Post: 03-25-2005, 02:14 AM
  4. WTB: Xenarc 7" front plastic housing
    By gork in forum Classified Archive
    Last Post: 08-09-2003, 06:04 AM
