Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Wooden Box Enclosure (w/ Pics).
  1. #21
    Maximum Bitrate starfox's Avatar
    May 2002
    This might be one time when we can go "lol ECS ahahaha" This board is a P4VXAS (, and I believe the CPU voltage is regulated off the 5V supply instead of the 12V supply, so that might be saving you a lot of problems. Actually i'm not even sure if the 12V supply is used on those motherboards...
    Anyhow, if it works, good for you.
    But do consider running a regulator of some sort, it'll make your components last longer.
  2. #22
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by pRoFiT
    Oh damn, Dont tell me your running that system right next to your subs! You must have a good hard drive. Most hard drives will go into a protect mode at anything more then 1G of force. Please....what is the make of your hard drive
    Fine, I won't tell ya but, I'm using a Western Digital WD1600 (160 GB), look (all the way in the back) here.
    I have an alt that runs at 14.3volts and my system will shut down at that voltage.
    My stock alternator is old; I've never changed in 7 years/107,000 miles.
    I had to cut it up and wire a 15amp regulator to make it run stable.
    Can you link me to you it please? Also, how much did you pay for it, I'll probably be on a lookout for one just to save the Hard Drive.
    Is that a 1000watt 5.1 suround amp and does your computer output 5.1 to it?
    No, it's actually a 4.1 amp (140W x 4 + 440W x 1), and you won't believe this, but I picked it up at Fry's nearly a year ago brand new for $50.
    So my audio setup is:
    • 2 front - to the amp's front inputs.
    • 2 rear, splitted with 2 RCA Y-adapters - to the amp's rear & sub inputs.
    I ran my system today and everyhing seems stable. Im still in the modding proccess
    Good luck! Post some pics up of how it's like so far.
  3. #23
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Okay I just made this site so I could put all my pics on it. Nothing fancy.
    some of the pictures are big so it ight be slow. i will have to go back and make them smaller files.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage.
    Modified RRSkinEditor
  1. I'm dating a deaf chick
    By Grayscale in forum Off Topic
    Last Post: 02-22-2006, 04:47 PM
  2. Replies: 42
    Last Post: 09-13-2005, 09:31 AM
  3. Sub Box Style
    By heezer7 in forum Car Audio
    Last Post: 05-26-2005, 03:49 AM
  4. new setup pics
    By freestyler in forum General MP3Car Discussion
    Last Post: 06-06-2002, 12:08 AM
  5. Some pics of prototype DIN box....
    By cenwesi in forum General Hardware Discussion
    Last Post: 06-01-2002, 09:07 AM
