Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: plexiglass case
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    plexiglass case
    I've been reading about making plexiglass cases. I just picked up 6 piece of plexiglass i had cut to make a box. I've been reading about drilling it slowly to not melt or break it. I haven't seen too many specifics on other aspects. For instance, is there a recommendation on putting it together? I assume i put holes in it before assembling it, or am i wrong? also, i know how to drill it, but is there a way to cut square holes for the motherboard connections? I want holes for the fans and wires, most can use drilled holes, but i may want some rectangles. I have a dremel w/ a ton of bits. Should i masking tape anything to keep it from cracking? Should i leave teh protective paper on?
    any advise would be helpful. thanks!
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    Nov 2004
    I hate saying but do a search.
    Plenty of info on here.
    Anyway I have made a plexi computer case for my MB.
    I have used a Jigsaw for rectangles and file it down for a good finish.
    I coping saw will be good also.
    I have tried a cut off wheel on a dremel but it produced some heat and slightly melted the edge of the plexi.
    Always leave the protective cover on it until you are 100% finished.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Small holes are a pain... I've done them once, never again. Better idea: cut a rectangle big enough for all the ports to poke through and use the metal hole cover that comes with most motherboards.
    But, if you still want to do it, dont worry about heat from cut off wheels or high speed bits from your dremel. Go back over your cuts with a mini butane tourch. Just a touch with that will melt any rough edges. Lighters might also work, but I like that the butane under pressure gives a straight flame - at any angle - good for small holes. Lighters also burn dirty - you have to clean up the soot afterwards.
    There was also a thread on here about a guy with a laser cutter... Probably 6 months back...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Laser cut would be the way to go exact clean cuts. If you do not have access to a laser cutter. It is best to cut the holes with a jig saw and then file to fit. It is impossible to cut a square hole with a round bit.
    Yes leave the paper on till all work is complete.
    Drill the holes with a sacrifical board behind the plexi. It is best to clamp the plexi to this board. Doing so will help prevent blow out. Blow out is when chunks of plexi break off when the bit exits.
    Jun 2004
    Virginia
    thanks for all of the tips. I had great success for my first try! I had the glass pre-cut from the glass store. I traced out lines on the paper and cut them out w/ the dremmel using a drill bit. i cut holes and then moved it slowly to cut a line. finally, i went over it w/ the sander disc and smoothed it out. i made one hole for the entire motherboard and one for the connections on the connections on the power supply, but contored it to match every port/connector. I then drilled holes for each screw hole on the MB and epoxied the little motherboard risers. when i connected it, i connected a wire from the ground of the MB to the ground of the PS just as an extra connection. I drilled holes for the holes on the power supply and hard drive. I bought small bolts from Home Depot to attach. i epoxied the thing into a box using 5 peices. i still have to attach the top. i'll probably use a hinge or something. I just took my time and measured a bunch of times. I have a cordless dremmel and used it on speed setting #4 or almost everything. It definately melted a couple times, but you just stop and continue, nothing was damaged by any means. I'm going to keep this in mind for other projects! Quite a success!
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Post some pics if you can.
    TruckinMP3
    Read the FAQ!
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    How strong is the box being held together with only epoxy?
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    As far as getting the store to do it, what did they charge?
    How many cuts did you have made by the store?
    2000 Sunfire build 100%, or is it ever really 100%?
    Jun 2004
    Virginia
    Quote Originally Posted by CavityCr33p
    I'll post pics along w/ the whole project soon. i've been bad about that. As for the plexi, i bought 1/4" clear plexi. it was going to be $24 for the sheet w/o cuts but $48 for the glass cut into 6 peices (they charge $8 a peice for the glass, not by the cut). i opted to get the pieces they cut. i have no idea if this was a good buy or not, but i'm very pleased. they cleaned up the edges and such as well and knew a lot about it. they answered all of my questions about working with it.
    Jun 2002
    Colorado
    If you are happy with the price, must be a good deal
    TruckinMP3
    Read the FAQ!
  1. Information on the Opus case?
    By Lord_Pall in forum General Hardware Discussion
    Last Post: 12-07-2004, 06:11 PM
  2. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 05:50 PM
  3. Cheap Plastic case for Carputer
    By NiN^_^NiN in forum Fabrication
    Last Post: 09-11-2004, 04:52 AM
  4. Looking for a case...
    By gork in forum General Hardware Discussion
    Last Post: 08-05-2003, 02:02 AM
  5. Cool looking case for fv24
    By B3AND1P in forum General Hardware Discussion
    Last Post: 04-20-2002, 12:28 PM
