Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: SEM Paint Problem
  1. #11
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    You can not get a high gloss finish wet sanding a single stage paint. If you want a high gloss deep finish then you need to clear coat the part.
    I would follow Altimat directions. A few light dry coats with a one...maybe two wet coats. I would not do several wet coats unless you have to and if you do make sure there is enough dry time between coats for the paint to flash. If you layer up wet coats without enough to dry the solvents can "pop" and mess up the finish.
  2. #12
    Aug 2009
    painting hard plastic
    the best method for painting hard plastic for us has been to clean with the Sem scuff & clean, followed by the Sem plastic/leather prep. Then use the two step application of the Sem plastic adhesion promoter prior to coloring. As everyone else has said.....spray especially when using an aerosol when the humidity is low. Do not hold the can too far away and you should achieve good results. If there is a little "blushing" one can use their heat gun carefully to get rid of that.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. To paint or not to paint
    By cavramair in forum Car Audio
    Last Post: 05-21-2005, 03:59 PM
  3. SEM paint
    By Quattro in forum Fabrication
    Last Post: 04-09-2005, 03:00 PM
  4. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  5. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
