try painting with wetter coats. Hold the can closer to the dash peice. You will have to meve quicker to avoid running.
There is always wetsanding. It depends wether your texture is peaks of valleys. If peaks then you can just wetsand until smooth. If valleys then will have to spray another coat to fill in the valleys.
question.... was it really hot out when you painted? If so then thats why you have texture becasue the paint dried a little too much before it made contact with your dash peice.
BTW post a picture
LinkBack URL
About LinkBacks
but I noticed a problem with my paint job. My dash piece came out with a textured finish to it. I have been using SEM paint for a while and have never had any problems like this. This was also a fresh can of paint. In order to achieve that gloss finish I am assuming I am going to have to wetsand now
Has any one else had problems like this. Thanks in advance!
and bust out the sand paper and smooth it off. You could have it done it 1 hour.
