Results 1 to 10 of 11
Thread: used too little hardener for the bondo
    Newbie fullgrown's Avatar
    Jul 2005
    West Lafayette, Indiana
    Question used too little hardener for the bondo
    i'm relocating my HU for my civic. and i'm using bondo to fabricate the new location for my HU. but the thing is that I used too little hardener for the bondo. do i have to wait days for it to harden or can i do somthing else to make it harden faster? and i don't want to put another bondo on top of it with more hardener cause i already did 3 layers of bondo and i'm not really good at using bondo. any help????
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    You'd be better off cutting it out and doing it again as nine times out of ten it will stay soft and it will ruin the install
    Jul 2005
    so the bondo without enough hardener will never harden???
    Fusion Brain Creator
    Mar 2005
    sucks to be you!
    practices makes perfect
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    yeah, even if it "hardens" it wont be hard.....always overestimate your hardener, and work fast.
    PC Components:
    My work log
    May 2004
    NJ
    Quote Originally Posted by Peoples
    You can't do that either! depends on the material used, too much hardner will either turns it into gell (epoxy/resin) or it will be brittle (body filler) and cracks.
    Jul 2005
    yeah, i had to redo my bondo with little more bondo...had to work really fast. i got a question for you experts with bondos. how do you guys put on the bondo? with brush, or with hand?? i had to work with my fingers to make them smooth cause the brush didn't really work for me.
    May 2004
    NJ
    Use this , they come in various sizes.
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    where ever you bought your bondo, esp auto parts stores, they sell the bondo brand "plastic spreaders"
    ive never used a brush, i dont even see how you would. the great thing about the plastic spreaders is that when the bondo dries on them, you just flex and the bondo breaks right off. its wonderful clean up. they even come in the exact color that your hardener-bondo mix should be, for easy mixing. they are really amazing.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Jul 2005
    Central Valley (CA)
    Quote Originally Posted by fullgrown
    Your gonna want to use the spreader that Kingtut mentioned. Just be ready to sand it. Your never going to put it on smooth enough not to have to sand it. Then after sanding it your probably going to see some pin holes, thats where the glazing putty comes in. Then sand the glaze......
  1. smoothly bonding metal and bondo?
    By Dexter in forum Fabrication
    Last Post: 03-12-2009, 11:54 AM
  2. I hate Bondo
    By djXternal in forum Fabrication
    Last Post: 05-14-2005, 02:25 PM
  3. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  4. Bondo won't Dry! Just Stays tacky!
    Last Post: 12-05-2004, 10:11 PM
  5. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
