Results 1 to 9 of 9
Thread: fabrication agents
    Jul 2005
    fabrication agents
    well i hae serached and searched and yet to find anything useful, im looking for the stuff that everyone uses to mould in the casing for my LCD monitor into my dash, so it look orginal...
    what is the stuff called and how much is it usually and how much will i need?
    cheers
    sean
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    epoxy + bondo + putty + lots of sanding paper + lots of time + paint + lots more time
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    Abs sludge or paste. Do a search
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    A new GF because the one that you have (saying that you have one) is going to leave you because you spend more time with adhesives that with her
    Good luck....
    Thanatos.
    Edit:
    Just to be on topic you also will need sanding block,tape,newspaper or plastic (to cover you work area).
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    snr88.....there are several methods used to mold the dash. It is best to first determine what you are looking for before anything. Do you want a factory look or something that is obviously custom? Most of the materials are the same except for the finishing products. Often what is used is what is readily available. I will tell you what I use on my personall cars and customer cars.
    For inital bonding and most of the build up I use 3M Automix for semi rigid plastics. It is also available under the name Duramix. I used to use alot of epoxies but this stuff blows epoxy out of the water for this application. Once it is bonded in built up I use Rage Gold or Rage Extreme to smooth fill deep scratches. Then I use a high fill 2k primer and then to a final finish. Either high gloss paint or factory texture and factory colored paint.
    If you have a local autobody supply shop then all the products you would need should be available there. There are places online like www.autobodydepot.com But I would recommend buying local. Hopefully you have a local place with cool people in it that can help you with product selection and application.
    Jul 2005
    thanks heaps for the info SickVette, helps alot
    well i want it to look as factory as possible...
    anyway keep the advise commin guyz
    cheers
    sean
    Jul 2005
    Townsville, QLD, Australia
    Hey mate, you got the dash yet?
    Jul 2005
    Quote Originally Posted by michaelhaynes11
    nope, should turn up tomorrow (i hope, wen ya send it mate?)
    Jul 2005
    Tuesday. Should be there soon
  1. Need to hire a fabrication expert
    By vladilen in forum Fabrication
    Last Post: 06-16-2005, 01:29 PM
  2. Custom Fabrication Work?
    By mattdisaster in forum Fabrication
    Last Post: 02-01-2005, 12:37 PM
  3. Replies: 35
    Last Post: 01-12-2005, 02:10 PM
  4. Altimat new fabrication moderator
    By Zip-Lock in forum Fabrication
    Last Post: 11-13-2004, 11:57 PM
  5. Fabrication sub-fourm
    By Zip-Lock in forum Mp3car Forum Suggestions/Comments
    Last Post: 04-15-2004, 01:05 PM
