Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
Thread: 2003 Toyota Matrix install
  1. #31
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Jahntassa
    I think gmpartsdirect.com has the bezel for around $26 or something..but I can't remember what the part number is.
    I went the opposite way with my Vibe, and mounted the screen behind the existing bezel, as I didn't trust my fabrication skillz.
    I think mouting behind is a better way too if you can relocate the LCD button else where (vertical on the side?). Mount it such a way that you still can push/adjust/tilt the LCD viewing angle. That will help a LOT with glare reduction.
    The GPS screen on the Siena van can be tilt adjust to the best viewing angle base on where/when the sun hit the screen and I really love that.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #32
    Aug 2005
    New HU location?
    MatrixPC and Matrix_24. I had a question about the placement
    of the HU where the cig. lighter originally is (below the air controls).
    I noticed you guys were talking about moving the 110VAC outlet etc,
    however in my Matrix that area is occupied by a cig. lighter on
    the left side, and a small storage area with cover taking up the right
    3/4 of that area. The problem with that cover is that it's the type
    that swivels open, it's not simply a cover.
    I'm wondering if you guys had a different situation and simply cut
    into that piece.
  3. #33
    Sep 2003
    Beach City, Socal
    The only different with the 110VAC option we (Matrix_24 and I) have and yours is the cover right of the cig lighter. With the 110VAC, the cover just have 2 hole that hold the plug and the switch. Behide it is a "box" like you said.
    Just use a sharp ultility knife to cut it out to the size of the HU body. It is very tight fit (openning). Depend on HU, you may have an inch and half or less. Mine has about an inch which is enought for all the cables/wires. Make sure to make some "creative" hanger/mount so that the HU won't rocking up/down with pothole/speedbump.
  4. #34
    Constant Bitrate Matrix_24's Avatar
    Jul 2005
    IL
    Quote Originally Posted by uncrase
    into that piece.
    I have a base model, so I had the storage area too. I used a dremel with a cutting wheel and first started by cutting the box off the back. Once the box is off you can start measuring and cutting. I did a lot of cutting and test fitting. Be careful, the piece that goes around the shifter is barely held on once you are done cutting. I guess it does not matter too much if it comes loose, it will all go back into place. To take that center section out remove the center dial by pulling it out and there is a screw there. After that there are 2 pronges that hold it in at the top. To get to those I removed the silver pieces on the side and there are holes to get a small screw driver into. The part around the shifter comes up easily with a small screw driver too. I did not have to alter anything other than the front piece. I saved the door to the storage compartment and cut it to make sure I did not have a little gap on the side.
    You can either put the cig lighter somewhere else or rout it to the location where the screen is for power.
    MatrixPC, what are you doing for power, I am getting flickering and thinking it is the cig lighter power. I need to test with the AC adapter today to see if that is the problem.
  5. #35
    Jul 2005
    IL
    Quote Originally Posted by MatrixPC
    I did not hmake a mount. Mine is such a tight fit it will not move even by wiggling in from inside the dash. It is so tight that if I need to remove it I need to push it out from behind the dash, I can't simply pull it out.
  6. #36
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Matrix_24
    The Lilliput is power by the EGG and plug into that cig adapter.
    The screen sometime fliker but that is like 5% so it is acceptable for me. Maybe someday, I just have to power it by the PSU. I already has the power wire up from the PC to the LCD. I just lazy to wire up a relay to power the LCD.
  7. #37
    Aug 2005
    So I completed step one of the process... I actually went to a salvage yard
    and they had an '03 Matrix (the poor thing was completely totalled!)
    But at least the radio bezel as well as the lower mid console section
    were still in good shape. So I had the guy rip me off and I ended up
    paying about 40% of the new price. But at least I have peace of mind
    that I can put back the original parts when I change cars.
    So I'm almost ready to put my new HU in, but I'm wondering where you
    guys found the wiring information for the Matrix? The plug seems to be
    proprietary so I'm going to have to rewire to the Clarion (new HU) plug,
    however I can't seen to find the details of which wire is which.
    Thanks,
    Martjin
  8. #38
    Jul 2005
    IL
    If you are talking about the wiring for the radio, I bought an adapter (you could get tem any where) and it had the wiring on the back of the package, HERE IS A LINK TO IT. It tells you how to solder it to the harness that comes with your aftermarket radio.
  9. #39
    Aug 2005
    I ended up getting that exact adapter at my local store (Futureshop). I had to go
    back once because I thought it wasn't working but that was because I didn't hook up
    the "accessory 12V" line. Anyway, I finally got it completed (the new HU part).
    It definitely fits very tight, although without the metal it's definitely still prone
    to threft. However I did realise some interesting coinidence. Since I have an
    automatic, you can not move the shifter out of P without turning the key.
    And with the shifter in P you could never get the radio out of that position.
    Now lets hope that if they ever break in they don't try to force the shifter out of P.
    I was wondering BTW about the heat dissipation with the HU in this alternate position.
    Do you guys have any problems with that? I know the whole case acts as one big
    cooling, however in the case of the stock radio, this metal case is connected to
    a big metal safety bar that's behind it. With this new HU the heat is not really
    disspated. I was wondering if this has caused you guys any problems?
    Cheers
  10. #40
    Jul 2005
    IL
    Cheers
    I have not had an issue with heat. I do not know what you are talking about with the safety bar, mine did not have that.
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. 2003 "SVT" Ranger Carputer Install
    By SVTRanger in forum Worklogs
    Last Post: 10-29-2006, 02:55 PM
  3. 94 Jeep Grand Cherokee Install
    By jamiewhittingha in forum Show off your project
    Last Post: 08-02-2006, 02:02 PM
  4. 2003 Custom In-Dash 7" Touchscreen Install
    By nirvanades in forum Fabrication
    Last Post: 04-06-2005, 05:33 PM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
