Results 1 to 10 of 10
Thread: Styrofoam mold made, now what?
    Jul 2005
    I've been doing a lot of a reading lately about fiberglassing, but I am stuck. I went to menards and bought a sheet of 2 inch pink owens corning foam insulation and glued it together with foam caulking. Then i sculpted the foam how i wanted it and now im stuck. Do I absolutely have to bondo this first? Or can i just put fiberglasson it how it is? If in fact i can just put fiberglass right on the foam, how do i do the final prep work so its all smooth? Does anyone have any reccommendations on what I can use as a relase? Any help would be greatly appreciated.
    Newbie etown's Avatar
    Jun 2005
    Shilo MB, Canada
    Fiberglass straight to the foam. When it's all cured you just melt the foam away with thinner, then bondo for a nice smooth surface.
    Newbie 91silvy's Avatar
    Jul 2005
    Arr-can-saw
    Do NOT fiberglass directly to the foam. The resin will eat through the foam ruining your nice sculpting work. Put a nicer layer of painters tape over the foam so the resin can not get through.
    J-Bock
    Apr 2005
    Also, put Vaseline on top of the painter's tape so you can easily remove the mold from the foam afterwards.
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    http://www.buildyouridea.com/foundry...oam_howto.html
    you could always do that^^^ (something ive been thinking about doing for my dash. would require alot of Al, and a lot of venting)
    seriously tho, using that drywall texture mentioned above has worked great for me when doing molds for fiberglass. and vaseline works well too.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    yeah dude hes right put some tape and tin foil over the foam so it will hold its shape and not melt with the resen... and yeah vassaline works or car wax the bottle kind not the can kind...
    Jul 2005
    If I dont care to ever use the mold again can i just put painters tape and then melt the foam with thinner and peel the tape off from the inside? I will most likely be fiberglassing this evening. Any more hints or cautions would be great. Thanks!
    Dec 2004
    well why would u go the hard way and melt the foam with thinner whe nu can just pop the mold lol and if u mess up bonding or it cracks or wahteve u can use that mold to start over insted of emaking the styrofome
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    You can seal the foam with latex paint. Resin won't dissolve that.
    Fabricator
    Jul 2005
    I finally finised my fiberglass housing for my screen, and now I need a good glue to fix it to my dash peice. Does anyone have any suggestions on what to use for this? It would be nice if i could also use the glue to feather the fiberglass housing to the dash so it has a finished look. Any suggestions are greatly appreciated. Thanks!
  1. Mold making
    By CrzyOne01 in forum Fabrication
    Last Post: 12-04-2004, 09:46 PM
  2. Making a mold after dash customize ??
    By Don 944 LA in forum Fabrication
    Last Post: 11-06-2004, 04:41 PM
  3. question about making a mold
    By zaxxon in forum Fabrication
    Last Post: 07-29-2004, 06:36 PM
  4. Replies: 4
    Last Post: 04-10-2001, 01:10 AM
