Results 1 to 8 of 8
Thread: Remote Faceplate - Detatchable wiring
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    I have been wanting to do this ever since I got the screen into my car, and the HU in the glovebox. I saw another thread here, and was just about to get started on it, but stopped.
    I need to find a way to make the wiring detatchable:
    Faceplate - wires - connector - wires - HU "box"
    Ideally, I would have only one set of wires (18) so that it was just a single cable, but I haven't been able to find anything like that.
    I looked at a moniter cable (I believe) and it would work out nicely, if there were more wires. It plugs into itself, so there is no need to worry about wires matching up (I hope, can anyone really say?).
    Any other ideas?
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    DB 25
    Centronics 25
    SCSI: centronics and mini centronics...
    there are a lot of standard plugs available that have connections pins or more, just take a pick
    May 2005
    RI
    Thanks for the start.
    You wouldn't happen to know if any of them have cables on the inside that are marked, by color, number, anything? So that there was less of a guess to get them to work, though, I suppose if I chopped it in half, connected both ends, and then used something to test the current, only the correct wires would flow, right?
    Mar 2004
    Ghent - Belgium
    Yes, right.
    Most of these cables are colour-coded, but it depends on the manufacturer, not so much on the standard.
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    I can't imagine it would be too hard at all to figure out which wire goes to which pin. You could just use a multimeter, or just use a battery and a small LED or something.
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    the biggest problem i can see, is that a HU wouldnt need huge amounts of current, so a printercable wire gauge would be an overkill. And as i have found out- the smaller the cable - the easier to wire. Whats the best place to look for 18+ conducter cable with a sheath size the same as cat5?
    92 Subaru Legacy Wagon
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    16x2 Charater Display
    Creative IR Remote
    VIA Sereniti 2000 Mini ITX Case
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Diamonds are for girls- wise men follow the stars
    Jun 2000
    NYC
    A few people have done this on the site...I'm too lazy to search.
    Newbie crowdesign's Avatar
    Jul 2005
  1. Remote faceplate! turned out really nice, check it out
    By Sporttracguy in forum Car Audio
    Last Post: 02-23-2007, 02:07 AM
  2. Remote faceplate almost done
    By volvo9 in forum Fabrication
    Last Post: 02-05-2006, 11:39 PM
  3. Remote faceplate - half way there
    By rustyboxx in forum Car Audio
    Last Post: 11-12-2005, 04:44 PM
  4. detatchable faceplate to control pc?
    By scott_fx in forum Hardware Development
    Last Post: 04-19-2005, 01:50 PM
  5. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
