Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Door pod - to cut or not?
  1. #21
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    OK, nearly ready, final few sandings and fillings. Three-layered fiberglass.
    I'm 215lbs....
    1996 Volvo 850 T5 CD - Eventually I'll start....
  2. #22
    Aug 2004
    Ann Arbor, MI
    Polyfill's main purpose is not as a quick-fix to an enclosure that is too small. If that is the intended reason for its use then serious revisions need to be made to your design. Its used to stop standing waves inside an enclosure. The possitive "side effect" is that it fools the driver (and sometimes the listener) into seeing more space as the soundwaves get translated into heat instead of reverb. There is an audible difference between polyfill used to decieve and polyfill used to enhance. I believe the general rule of thumb is 1lb. per sq.ft.
  1. Cut up (physically resize) old LCD screen?
    By TravisD in forum Hardware Development
    Last Post: 04-08-2006, 05:58 PM
  2. Article: spy device will cut driversí speed by satellite
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 08-06-2005, 10:22 AM
  3. Momemtary switch to cut all power to comp
    By PatO in forum Hardware Development
    Last Post: 04-19-2005, 07:17 PM
  4. best way to cut plastic?
    By TxMazda3 in forum Fabrication
    Last Post: 02-12-2005, 09:17 PM
  5. Program to cut the length of mp3 files???
    By zzsprade in forum Software & Software Development
    Last Post: 08-04-2002, 05:40 PM
