Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Door pod - to cut or not?
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Hi,
    I'm no sure what the cpvering of my door is, vynil I think, but I'm wondering will the fiberglass stick to it?
    Also - Would it be an idea to leave the door card intact, ie not cut a hole through it, thus creating a sealed pod?
    L
    1996 Volvo 850 T5 CD - Eventually I'll start....
    Low Bitrate Enak's Avatar
    May 2004
    Hertfordshire, UK
    Stretch an old t-shirt or something similar over the build and staple this to the door. Then build your fibreglass over that.
    Apr 2005
    Ireland
    Will the 'glass stick though? I've taken them off th door, and am going t ocut a square MDF panel and build around that, bolting it to the door
    May 2004
    Hertfordshire, UK
    Should do.
    The Tshirt will help hold it in place... it is possible that the vinyl will flex and cause the fibreglass to crack in later life.
    Key the surface with some wet and dry before you start to give a good surface for the fibre glass to attach too.
    Are you retrimming the doors or planning to paint the vinyl?
    Apr 2005
    Ireland
    Paint the vynil. Or suede-cover the lot. I'm sick of the dash at present and want to change it. I eventually decided to work on the pods off the door - built onto an MDF panel, which I'll then bolt tothe card
    L
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    First...NEVER use a tshirt. You are asking for LOADS of body work when you use a material that thin. Tshirt material, speaker cloth, and other thin materials get very wavy when you apply resin to them. Then you have to apply alot of matt and do alot of body work. Use fleece or sweat shirt material...you can get both at Wal Mart. The material is alot thicker and will hold a much better form. You will have gobs less time nito making them smooth. If you plan on covering the panels with suede or vinyl the finish has to be perfect or any flaws will shine right through the covering material.
    Second fiberglass does NOT bond to plasitc. You would be better of bonding a piece of wood to the door panel and attaching the fiberglass to that.
    When I build fiberglass door panels I do it on the car. Reason being is the door will hold the door panel true to form. IF fiberglass is kicked too hard it can cause the panel to warp and then it is toast. You are building a small panel so you will not likely have that problem. Keep in mind all your clearances...like where the door panel meets the dash board and sill panel.
    Apr 2005
    Ireland
    SickVette - the Tshirt came out perfect, then I put two layers of fiberglass mat over it, and now I can just about stand on it.
    *frantically scratches lower arms*
    One second and I go take a picture of one pod, pre sanding and etc
    Apr 2005
    Ireland
    Tada!
    The other pod was in the oven for a little bit too long...orange fiberglass lol
    May 2005
    Wesley Chapel, Fl
    It is cool you got that going but sorry that is not perfect. See all the white and black spots...those are air bubbles and they are very bad. Air bubbles will cause delamination...seperating of layers. Not to mention all the waves in the glass. You are going to have some fun grinding on those panels. I am sure in the end if you put in all the time and effort they will come out nice. But it could have been with much less time and effort. What is this about an oven? You are sticking these pieces inside of an oven?
    Apr 2005
    Ireland
    Trust me, they're smoother than the fabric underneath, and the second pod hasn't anywhere near as many of them. I heat them in the oven with the door open to speed up drying time, and there wasn't alot of effort put into these. Cut out those air bubbles and build up again?! the glass mat coat is alot smoother than the fabric was underneath, and surely with enough layers of glass it can;t be all bad?
    L
  1. Cut up (physically resize) old LCD screen?
    By TravisD in forum Hardware Development
    Last Post: 04-08-2006, 05:58 PM
  2. Article: spy device will cut drivers’ speed by satellite
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 08-06-2005, 10:22 AM
  3. Momemtary switch to cut all power to comp
    By PatO in forum Hardware Development
    Last Post: 04-19-2005, 07:17 PM
  4. best way to cut plastic?
    By TxMazda3 in forum Fabrication
    Last Post: 02-12-2005, 09:17 PM
  5. Program to cut the length of mp3 files???
    By zzsprade in forum Software & Software Development
    Last Post: 08-04-2002, 05:40 PM
