to do that to a fiesta you will have to take the whole dash off.
why not take out the cd player and put the screen there? thats what im doing in mine! much easier to blend it in.
although the grooves in the plastic are the pain really!
Hello,
I want to install a 7"TFT in My dashboard. But I don't know if fibreglass and polyester will fix on my original dashboard? What's the best solution?
In attachement there is a picture of the original dashboard. I want to place the TFT in place of the 2 marked Air-vents.
I hope someone can help me...
Greetz,
SkyFlyer
Yups, I've taken the whole dash off. It's not difficult. The dash is made in 2 pieces, maybe I will take some photo's.Originally Posted by davebateman
I already tried to put the screen in place of the CD-player, but that was a very big problem. I had problems to connect the air-ventilation console.
Here a picture of my previous project:
So, this is the piece of the dashboard that I need to install the screen. Not the whole dashboard!!! But now I don't know how to begin with the polyester and fibreglass. Will it fix on my plastic dashboard??
Greetz,
SkyFlyer
Well if you worried about it structurely, you could drill small holes around where you're going to fill. These will help it bite. I've had alright look with bondo sticking to polypropelene, but you might want to look at Evercoat Poly-Flex. A filler for poly and other plastic car parts.
HAHA THE FOOT MAKES ME CRACK UP IM SORRY! lol
sand ur dash down like a mother f'er and drill holes like shotgunefx said
And I have to put the fibreglass-mats directly to the original dashboard?
It will fix? I will make some holes, So it will beter fix.
Skyflyer
Any reason your using mat instead of say kitty hair? (Filler with fiberglass builtin).Originally Posted by skyflyer
Not saying you couldn't do it with glass, for all I know you have a lot of experience, but from my slight experience with it, seems like you be better off with something else. Or make it out of glass and then mount it to the dashboard. When I was playing around with making a gauge cluster, I was able to remove the fiberglass pretty easily from the plastic cluster.
Ok, I've just cut out the 2 vents.
What product can I use to fix the screen on the good place temporary before I use the fibreglass? It's just to hold the screen on the good place when I'm working with the polyester... Some mousse???
Who can help me?
SkyFlyer
Fiberglass does not make a bond to plastic even if you drill holes in it. Your are better of using epoxy resin instead of polyester resin. Epoxy will will make a chemical bond to the plastic. Another product that might help you is called Automix from 3M or Duramix...same stuff. It is made for plastic repairs and works very well.
You keep mentioning you are working with polyester....what kind of polyester? Polyester is a material used in alot of different things....you could be trying to bond a pair of your grand pa's polyester golf pants into your dash for all we know....lol.
