Results 1 to 10 of 10
Thread: Respray Console - Vauxhall Astra G Hatchback
    Mar 2005
    UK
    Spent most of the morning deciding what i can do to my car, so i thought i might respray the console and air vents to colour code with the car, i have added some pictures below.
    I will post the images for the console when i do it tomorrow
    Mar 2005
    UK
    when i get some money put together which shouldn't be too long i will be including a display with computer in boot, cables already ran to back for power etc.
    Heres a design below,
    It will be embedded in about 3 or 4 cm so it has a border, help to protect from sun. also ability to make a cover to go over for security.
    What ya think ?
    Oct 2004
    That looks damn good. I'm thinking of doing the same in my AstraVan.
    Mar 2005
    UK
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    did you use a plastic primer before the top coat?
    it is funny how it is obvious that the same person who built your clock and HVAC controls built my Pug 306 ones. The general design, especially the mountings, and the materials are too identical.
    Mar 2005
    UK
    yeh i cleaned the surface to get rid of grease/dirt etc then primer then coated with about 4 or 5 coats of spray.
    my clock and everything else is standard mate..
    all the materials are brought from shop just up the road lol
    Mar 2004
    Bristol
    I know your clock and stuff are standard, i just meant that it was funny that different manufacturers use the same people to make them.
    So you didn't use any special plastic primer? Just normal car body paint?
    Mar 2005
    UK
    i used this primer to prepare the plastic.. then sprayed over the top
    Mar 2004
    Bristol
    what primer?
    Mar 2005
    UK
    i can't remeber off hand. but it was a bumper/plastic spray primer, that could be used on any surface
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. console subframe
    By turbochris in forum General Hardware Discussion
    Last Post: 03-20-2005, 01:58 PM
  3. Would this tool work for 1998 vauxhall astra
    By Skuzzle in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-20-2004, 01:55 PM
  4. FS: Gaming Console / Games
    By TheNoodPoopler in forum Classified Archive
    Last Post: 05-31-2004, 01:36 PM
  5. Mk1 Vauxhall Astra
    By -he- in forum General Hardware Discussion
    Last Post: 04-30-2004, 08:24 AM
