Results 1 to 10 of 10
Thread: Clear Epoxy, Cheap?
    Dec 2004
    Clear Epoxy, Cheap?
    I want to find some epoxy to use use on our pong table. Some of the stuff Im looking at is 40 bucks a gallon, wanted to find out if there is something better/cheaper avaliable.
    I think I only need about 2 gallons. Its going to cover a set of caps.
    Any negatives of using polyurathane epoxy?
    Aug 2005
    Near Buffalo, NY
    Wouldnt resin be better suited for that. Granted epoxy might be stonger but you go to a marine store and buy a 5 gallons of resin for cheap. Just a thought
    Dec 2004
    Quote Originally Posted by Jcarere
    Any more info on which particular type to get? And how transparent will the resin be when it dries?
    May 2004
    NJ
    clear (clean) = expensive , does not matter what you use.
    It is that simple, I pay up to $50 for a galon of resin called liquid ice, it is extra clear, sandable and transparent.
    Dec 2004
    Is that something about the clarity level of plexi glass?
    Again, I want to cover up beer caps and have 1/4" to 3/8" of the resin accross the board.
    May 2004
    NJ
    It is crystal clear. Liquid Ice You can go as thick as you wish, build up thickness though, you might have to apply 5 or 6 layers, this thing gets hot while curing. It is sandable, you might order sanding agent and mix it with it for "easy" sanding. Allow time for each layer to cure - 24 hrs. you might find dust or dirt on the surface, it is ok, just sand the dirt off (400 grit) before pouring the next layer.
    Dec 2004
    Do you know if you can get this stuff at any local stores?
    May 2004
    NJ
    Off hand, no, most likely it is available under some brand name, "liquid ice" is brand name for SelectProducts. Try exclusive marine stores or some plastic supply shop. If you live in NYC, there is a plastic store on Canal St. PM me if you find it, I work with it a lot and know what to/not to do with it as far as mixing is concerned. I have no problem sharing with others but I might miss your question.
    Sep 2005
    What your looking for is Kleer Koat table top epoxy.
    http://uscomposites.com/kk121.html
    Dec 2004
    Quote Originally Posted by old250
    Thanks, I think thats exactly what I'm looking for. I've used them before for some CF stuff, they're good guys.
  1. Cheap battery saver module?
    By fixumdude in forum Power Supplies
    Last Post: 03-11-2005, 11:20 AM
  2. Cheap AM Radio
    By ukchris in forum General Hardware Discussion
    Last Post: 10-27-2004, 02:52 PM
  3. Help me choose CHEAP LCD please
    By Dr Jeckyl in forum LCD/Display
    Last Post: 04-13-2004, 12:27 AM
  4. A very cheap way to power your PC
    By clint_jasper in forum Power Supplies
    Last Post: 01-08-2004, 10:40 PM
  5. cheap sproggy parts source needed
    By drwho in forum Power Supplies
    Last Post: 09-14-2003, 08:47 PM
