Results 1 to 8 of 8
Thread: Spraying trim
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Spraying trim
    Hi,
    Some parts of my trim are plastic, which is easy to spray.
    But others are like vynil-covered...possible to spray this ****?
    L
    1996 Volvo 850 T5 CD - Eventually I'll start....
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    you seemed to of answered your own question.
    Apr 2005
    Ireland
    It stuck, but I broke the car ages ago, so I can't remember exactly what happened.
    Sorry, My question was kinda bad. Had any experience of it lately?
    Mar 2005
    Maryland
    if its prepped correctly, you'll be fine. put protective clear coats over it all.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Sound Stage
    Eclipse|MTX|Infinity
    Apr 2005
    Ireland
    ta. standard car paint work?
    FLAC -zip-'s Avatar
    Ontario/Canada
    If you prepare correctly you should be ok, clear coats as stated above. But why not go with paint that is made for the surfaces?
    Here is an shot of what I did. There is not a single crack, fade, scratch after a year which includes temps of -30c and +35c. (Canada has some really radical temp swiings)
    The paint I used is called Krylon Fusion, but works with plastic.
    Sound Stage
    Apr 2005
    Ireland
    serious? I live in Ireland, **** all paint options ehre
  1. Plastic/Paint spraying robot
    By Scouse Monkey in forum Off Topic
    Last Post: 02-22-2005, 03:16 AM
  2. factory style wood trim
    By psuter in forum Fabrication
    Last Post: 02-16-2005, 08:55 AM
  3. Replies: 0
    Last Post: 01-14-2005, 01:34 AM
  4. How much can you trim down lilliput?
    By bmwperson in forum LCD/Display
    Last Post: 09-02-2004, 01:42 AM
  5. Help... question about trim kit
    By kid320 in forum Newbie
    Last Post: 07-26-2004, 06:40 PM
