the resin used during fiberglassing should hold a good bond to the mdf as long as you clean it well, if you use a low grit count sand paper and mar it up abit before the bonding it should hold even better.
alright... im gonna fab up a structure and one side is to be flat and straight... so my question is if i were to use mdf for the flat part (as ive read is best) whats the best way to attach the glass to the mdf?
CarPuter ProgressO meterO
[+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
visit me on the web at
http://gozips.uakron.edu/~cmk23/
and im hoping its possible to make it airtight with the same methods? (eventually i also plan on building a nice subwoofer enclosure... and obviously that has to be much stronger than my car computer enclosure im working on)
