Results 1 to 5 of 5
Thread: Epoxy or FiberBondo ?
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    After using Fiberbondo to fabricate two bezels I've been seeking out an alternative. As you know Fiberbondo is VERY messy but gets the job done. I'm also comfortable working with it.
    However I've seen poeple using Expoxy (don't know what kind) But it looks much easier to work with. My question is what kind are you using and where can I get it. Also whats its cost going to be (roughly) Thanks guys/gals!
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    If you do use epoxy dont use the 5min crap kind. Get a decent kind. I have used one from 3m that is medical grade stuff, that stuff is freekin gnarley. It takes a good 1/2 hour to 45 min to cure and then 24 hour hours until fully hardened but i applied it to some Poly Propolene plasitic and there is no way in hell its cracking or coming off.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i'm going with the abs welding technique right now and it is coming out a lot better then my last epoxy/filler dash. the piece is solid and can bend without cracking
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2004
    Maryland/NOVA
    scott... where did u get that abs stuff?
    thanks.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Dec 2004
    Los Angeles Ca
    i purchased a sheet of it from mcmaster-carr it's pretty cheap, i got a 12x24x1/8 sheet for about 7 bucks. you can also use black abs pipe to melt down.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Epoxy for PLexiglass
    By HummDinger in forum Fabrication
    Last Post: 06-08-2012, 03:00 PM
  2. Clear Epoxy, Cheap?
    By integramodder in forum Fabrication
    Last Post: 10-01-2005, 10:05 PM
  3. Epoxy - What did I do wrong?
    By blackflux in forum Fabrication
    Last Post: 06-06-2005, 11:01 AM
  4. Is Epoxy sandable like Bondo?
    By hd54321 in forum Fabrication
    Last Post: 05-06-2005, 04:06 AM
  5. Replies: 2
    Last Post: 04-09-2005, 01:29 AM
