Results 1 to 9 of 9
Thread: Attaching screen to mounting...
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Hi,
    about 50% through my dash build. I am now wondering how to attach the screen to the front of the case and hence, the whole build.
    I have included pictures of the screen from all four sides, and one of the dashboard. I was thinking maybe build a tray under the whole lot and have posts to hold the screen up?
    Anyone?
    L
    1996 Volvo 850 T5 CD - Eventually I'll start....
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    use little brackets on the back of lilliputs they have 4 little brackets that screw onto the front bezel and hold the screen inplace from behind and then the rest of the lilliput mounts to the front like a clam
    ur post idea is cool but what if the screen goes left and right how will u stop it from doing that?
    Apr 2005
    Ireland
    It's not a lilliput screen. I hear you though - brackets would be a good idea. I think I'm going to cut the back of the unit down a bit, and screw that on, as it was, but just reduce it in size, so it'll fit. In the mean time, keep the suggestions coming!
    L
    Dec 2004
    yeah i know its not a lilliput screen i was just saying use something like the brakets used on lilliputs
    Apr 2005
    Ireland
    cool. Any chance of a pic of those? I'm sure I can put two on the bottom, failing getting the back on. Then get two clamps for the top?
    L
    Apr 2005
    Ireland
    The thing is, that there is circuit board and bits (you can see them around the edges) that probably wouldn't take to happily to a clamp....
    Dec 2004
    well they usualy are 2 on the left 2 on the right ill try to find a pic and post it
    Apr 2005
    Ireland
    Ah! I'll do much the same. The screen fits tightly into the moulding...so all is going well!
    L:
  1. Replies: 21
    Last Post: 08-27-2006, 02:26 AM
  2. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  3. Help, mounting my screen in a calibra
    By Cheater2k in forum Fabrication
    Last Post: 11-30-2004, 09:14 AM
  4. screen mounting upside down
    By alienjj in forum General Hardware Discussion
    Last Post: 02-01-2004, 01:04 PM
  5. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
