Results 1 to 10 of 12
Thread: Plastic and Poly Carbon Polishing.
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    This isnt about amp cases, computer cases, or bezels, so read no furter.
    My Headlight are ambered-out and grimed out from the wear and tear and horrible aerodynamics of the jeep. I was wondering if this process I had in mind would work for getting rid of the grimetint and the scratches in my headlamps.
    Wetsand with 600grit. Dry, Wetsand with 1200 grit, Dry, Wet Sand with 2000 grit, dry. The Use a Scratch out remover. I have some Rubbing compound handy too. The scratch remover is: Kit "Scratch Out"
    Anyone have any advice? Should I hit it with a westsand 4000 grit too?
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    i think you can use nail polish remover? or acitone?
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    no! acitones KILL polishes. use something like "goo-be-gone" and if that doesnt work, yeah. do that process of wet-sanding, then wax over it.
    Mar 2005
    Plano, TX
    Alright, I'll take some before and after pics if anyone cares to see the results. I've been reading up, and this seems to be promising to restore headlamps without buying new ones.
    If all else fails I can always buy new ones off ebay.
    And clear nail polish remover is said to be used for stopping windowshield cracks. I cant tell you how many ricers I've seen with a window full of nail polish.
    NINe.2X, NINe.2
    Aug 2005
    If you sand the lens, you will ruin the coating on it. The Polycarbonate is not UV stable. The coating is turning yellow because it is shot, once the UV absorber begins to breakdown you get yellow. The layers of coating sluff off the outside as the UV absorber breaks down and then you have exposed PC, which weathers much worse than the coating. Microcracking and all out hazing will then occur on the lenses. There is nothing you can to a headlamp that will last very long with this issue, except replace it.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    After wetsanding, I'd use a fine polish like Menzerna Final Polish 2
    Quote Originally Posted by BLOWNZO6_pc
    What about clear coat?
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Jees, more than I ever needed to know about headlights.... But real nice info.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Mar 2005
    Plano, TX
    Yep, I tried wetsanding over the past two days...
    Was a dismal failure. I started to wet with 600, did it for about 30 min to get all the amber and grim out. Then did 1200, then 2000 wet, and then I tried the scratch remover, didnt work. So I went up to 4000 grit scratches, wetsanded again with 4000, and still no luck, now it looks like a ricer and I have to buy new headlamps .
    Oh well, you live and learn, just wish I could have not had to spend 100 bucks on new housing units.
    NINe.2X, NINe.2
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Are you sanding by hand?? If so then that is the problem. I am a technician and I fix these lights all the time with a polishing kit. I will see if I can find a link. It is the same process you are doing but not wet and much faster motion of the paper. I use a 3 inch foam padded DA sander. 1000 grit to remove grime and 1500 for polishing and plastic polish for final finish.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Aug 2005
    Quote Originally Posted by IntellaWorks
    LOL.. I do sales for a plastic injection molding company.. we use better than 2 million pounds of Polycarbonate a year and sell about $1.5 million+ per month in coated parts...
    Pretty much once the lenses are coated there is nothing you can do to them. People keep stating they polish and fix them, etc. If you are able to polish them up, you are removing the coating, they are dead after the coating is gone.
    Tail lights are another animal.. they are typically not coated and made with PMMA, which is very polishable, etc.
    Good luck.
  1. What do i use to bond PP plastic and Xenarc case?
    By Will Albers in forum Fabrication
    Last Post: 07-15-2005, 10:06 AM
