Results 11 to 20 of 24
Thread: What filler to use?
  1. #11
    May 2005
    First layer of paint:
  2. #12
    Oct 2005
    What product did you end up using for filler? How did you keep the filler from covered the holes for the buttons? Thanks
  3. #13
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    [OFF TOPIC] Sorry for thread hijack, but somehow related
    The developer(s)/site admin(s) of this site http://stage.sherwin-automotive.com...ct=29778&cat=37 (link given by thanatos106 in post #2) should give 2 weeks vacation at the beach with no paid.
    They didn't turn off the ColdFusion debug dump. It shows every single querries run to retrieve the page.
    [/OFF TOPIC]
    Now that fab job look nice. Which product did you use?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  4. #14
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Hah?
    Am I in any danger here??
    Thanatos.
    Edit:
    Very nice job with the dash trim.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  5. #15
    May 2005
    Quote Originally Posted by 03SVTLightning
    I've smoothed the small grooves between the buttons and around the screen and I was carefull not to put filler in the holes. I filed away the bits of filler that got in the holes once the filler dried. I also removed the led above the volume +- button. I forgot to take the transparant plastic out before I started sanding, so it looked like ****. I just put filler over it, sanded and sprayed it. Now you can't tell there was a button there, unless you knew it was there before.
    Quote Originally Posted by MatrixPC
    Thanks!
    As said a couple of posts above:
    I've ended up using "Alabastine Polyester Plamuur" :
  6. #16
    Oct 2005
    England
    that the remote reciever aint it?
    all fitted but its having a wobler!
  7. #17
    May 2005
    Yeh and it has a blue led behind it, I removed it because I never use the remote anyway.
  8. #18
    Oct 2005
    hey meelobee, in the beginning of the thread you said something about filling small holes with a filler primer? I'm using polyester plamuur as well but having lots of those holes, what did you use for those?
  9. #19
    May 2005
    I first tried to get them filled as much as possible with the poly plamuur, applying plamuur, sanding repeating that like 20 times ,which took a while (a weekend) untill most were gone, then I used Alabastine Spuit plamuur (filler primer) to fill the last pits But that didn't really work, the filler primer is not thick enough to fill holes, to me it looked like normal primer. (maybe I didn't apply it thick enough)
    So basicly I did most with the poly plamuur and alot of patience. Also using some kind of spatula (creditcard or something like that) really helps.
  10. #20
    Aug 2005
    CA
    Would fiberglass resin work as the last step to fill in all those stupid little nicks and holes on the bondo? b/c i am right at this step right now, and it is so annoying.
  1. Stage 1.. Fabrication
    By CdRsKuLL in forum Fabrication
    Last Post: 11-16-2005, 11:32 PM
  2. My first true bondo job. Mazda 3 dash.
    By nappyjim in forum Fabrication
    Last Post: 05-21-2005, 12:24 AM
  3. HOw to make it look flush?
    By kickercivic1 in forum Fabrication
    Last Post: 01-05-2005, 08:17 AM
  4. respirator vs. dust mask
    By saikano in forum Fabrication
    Last Post: 09-24-2004, 04:10 PM
  5. Fiberglass over foam?
    By gork in forum General MP3Car Discussion
    Last Post: 08-20-2003, 05:57 AM
