Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: What filler to use?
  1. #21
    Oct 2005
    Quote Originally Posted by casurfer911
    Would fiberglass resin work as the last step to fill in all those stupid little nicks and holes on the bondo? b/c i am right at this step right now, and it is so annoying.
    I wouldn't recommend it. I'd use a USC Icing or a similiar product.
  2. #22
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    If you are getting alot of pinholes you are not mixing the filler well enough or kicking it too hot. The filler should have an even color hue to it all the way through and mix it colder then it should be. This will give you a little extra time to finese it. Rage is proably the best filler available. I have yet to use anything comparable. Also body filler will not fill small pinholes nor would resin. You need a pinhole filler material like mentioned above.
  3. #23
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    A few always get past me and are not filled with the primer. I fill them in with a small pointed brush and some primer after the last coat is sprayed.
  4. #24
    Oct 2005
    I will back Sick Vette up on his claim. I have not found any other products that can compare to Rage Gold. I use USC Featherite, it's similar, and half the cost. When you go through as much of it as I do, the cost is a big factor.
  1. Stage 1.. Fabrication
    By CdRsKuLL in forum Fabrication
    Last Post: 11-17-2005, 12:32 AM
  2. My first true bondo job. Mazda 3 dash.
    By nappyjim in forum Fabrication
    Last Post: 05-21-2005, 01:24 AM
  3. HOw to make it look flush?
    By kickercivic1 in forum Fabrication
    Last Post: 01-05-2005, 09:17 AM
  4. respirator vs. dust mask
    By saikano in forum Fabrication
    Last Post: 09-24-2004, 05:10 PM
  5. Fiberglass over foam?
    By gork in forum General MP3Car Discussion
    Last Post: 08-20-2003, 06:57 AM
