Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 2005 Grand Cherokee...Need help with fabrication
  1. #11
    Dec 2004
    Orlando, FL
    Quote Originally Posted by Sillydipstixs18
    So my question is, since im using model airplane wood(balsa or ply) to make the frame for the screen and make room for the hu, do i need to make the dimensions of the frame smaller for the thickness of the material i use to make radio bezel? and the dimensions listed for the lcd are those of the case? i have a feeling they are.
    I want to use the stuff that Altimat used:
    Alternative to Fiberglass
    Does that make any sense?
    @Derbis - What is the dimension on the opening of that bezel? (for the nav unit)
    Car Progess Report:
    Planning: 100%
    Purchasing and Fabrication: 10%
    Overall: 10%
  2. #12
    Sep 2005
    dimensions with xenarc 700 inset
  3. #13
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    Put the HU faceplate in the visor and the box in your glove compartment or under the dash. I dont see where the HU is needed besides Radio, and maybe CD's, but other than that you computer should really do the rest.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
  4. #14
    Jan 2005
    Wilmington, Ohio
    If you must keep a radio, buy one with a detachable faceplate. Remote mount the faceplate somewhere on the dash ( i.e. -- little cubby whole by cigarette lighter), then keep the actual HU under the seat. I donít know if a radio is *really* needed when you can have thousands upon thousand of MP3sÖ
    See cubby-holeÖ
    Oh, look.... Tons of room back there.
    Wow, you think you donít have any room? Try finding room in WJ Grand Cherokee. I wish I had HALF the room youíve got there.
    BTW, in case you didnít know www.WKJeeps.com (Excellent recourse for your jeep)
  5. #15
    Sep 2005
    Quote Originally Posted by Distorted_Axis
    ...Remote mount the faceplate somewhere on the dash ( i.e. -- little cubby whole by cigarette lighter), then keep the actual HU under the seat...
    Damnit. I think my master plan just changed.
    ...maybe not. HU-less is cleaner.
    ...maybe...
  6. #16
    Dec 2004
    Orlando, FL
    yeah there is alot of room be hind the OEM radio. and i want to have the radio because i listen to the radio alot. more than cd's when im working. I have thought about remote mounting the faceplate.
    Car Progess Report:
    Planning: 100%
    Overall: 10%
  7. #17
    Dec 2004
    Orlando, FL
    Getting really annoyed
    I bought a Xenarc casing from this site to try out and make the trim piece that i want for my jeep. I spend at least 3 hours a day on this site (mostly when im working) reading on how people did their fab work an i do ask what you experienced people know, and so far everything fails, except the epoxy that altimat used (that turned at pretty nice for the small amount that i played with). ive read the how to's and the threads that are sticky'ed. im about to give up and pay some $$$ for the work.
    i wanted to make a mold of lcd bezel so that i could custom create the over head console to house one of my lcds. and most of what i read said to use great stuff and cover the bezel with it, but first coating the bezel with pam or something similar. so i did that. i coated heavy with pam, and sprayed the foam around to get a mold. well i let it dry for 2 hours and when i went to pry it off, it came off, but it was goo-ed onto the casing i bought. im using paint thinner to remove it, or i thought, no such luck because i wasnt thinking when i grab it, and it was acetone and it just ate the plastic case.....$25 dollars wasted. so back to stage 1.
    How can i make a custom overhead console using the epoxy that will fit to the contour of my roof? well i got the contour with a contour guide. :sigh:
    Car Progess Report:
    Planning: 100%
    Overall: 10%
  8. #18
    VENDOR - Centrafuse
    raygun's Avatar
    Dec 2004
    Atlanta
    updates?
    i'm about to buy an 05 grand cherokee.
    So was it hard to put in a 7" or 8" lilliput or xenarc?
    How did it turn out?
    reagan
    Reagan
    Formerly from Centrafuse
  1. 2005 Blue Mazda 3s
    By vcbb5 in forum Show off your project
    Last Post: 05-05-2007, 10:34 AM
  2. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 11:54 AM
  3. Replies: 0
    Last Post: 10-02-2005, 06:37 PM
  4. 2005 G35 Coupe Aftermarket Nav System
    By CAFHU in forum General MP3Car Discussion
    Last Post: 09-13-2005, 01:02 AM
  5. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 12:51 AM
