Results 11 to 20 of 29
Thread: BA Falcon
  1. #11
    Newbie bob^'s Avatar
    Jun 2005
    Geelong - Australia
    Yeah better than what I managed to get using a video card! Mine was constantly scrolling, just couldn't get the sync right.
    I used the following converter http://www.carconverters.com.au/prod...erter/236.html
    2004 Ford Falcon XR6
  2. #12
    Jun 2006
    Mt Isa Qld
    I have just bought an XR6 BA 03 it has the base ICC screen i thought of installing a Alpine IVA-D100E with the 6.5" motorised touch screen how would i go about wiring it and how could i install it into the tissue box? could any one help
    Jun 2006
    Mt Isa Qld
    hi
    i have just bought a BA XR6 falcon 03 with the base ICC screen I thought of installing a Alpine IVA-D100E with the 6.5" motorised touch screen could anyone help i need to know how i would wire it up and the best way to install it into the tissue box. thanks
  4. #14
    Jun 2005
    Geelong - Australia
    Pandaman, look up ArcadeVGA. You can use that in the BA on the ICC.
    Wardy, scrap the tissue box holder and make a new trim panel that goes in its place. For wiring, you have ACC and GND already behind the tissue box holder, aswell as the illumination wire on a light fitting thats normally used to illuminate a cigarette lighter if you have one.
    For constant power, run another wire from the battery side somewehre, just remember to fuse it.
  5. #15
    Low Bitrate Pandaman72's Avatar
    Jan 2006
    Central Queensland, Australia
    Quote Originally Posted by bob^
    Will try that, but I'm a bid worried. The video card I have now was supposed to work just fine, but obviously doesn't.
    I'll let you know if I find one and how it goes.
    Panda
    Car - Ford Falcon XR6 Turbo, footwell lights, Pioneer front speakers
    Carputer- P3 966MHz, 256MB RAM, 200GB HDD, 300W PSU
  6. #16
    Jun 2006
    Mt Isa Qld
    thanks bob whats the best way to make a trim panel and what would you use
  7. #17
    Jun 2005
    Geelong - Australia
    12mm mdf some rings bent up from fencing wire or the like screwed to the rear of the trim panel. That will let you use mounting holes.
  8. #18
    Dec 2003
    Just to add to my previous thinkings, from what i can tell the whole falcon uses a CAN bus, and up till now i didnt realise u could get USB->CAN interfaces which basically means it might be possible to implement software that controlls all the AC stuff with 1 little plug in USB interface. While this is just an idea, i might have to look into it. The can bus can controll the whole car including lock doors, change the channels on the FM tuner etc
    2 weeks till i get my BA!
  9. #19
    FLAC djmickyg's Avatar
    Feb 2004
    ive been tring to look for a CAN->usb thingy for a while now.. they seem to be the most expesive ones. they go for 150+ on ebay.
    if u manage to find something good then post it up please..
  10. #20
    Jan 2006
    I finally got it working
    Had to change just about every setting on the damn video card, but I got the correct combination in the end (after many, MANY hours of trial and error).
    Here's the proof.
    Now that I have finally got that sorted, I can move on to the easy stuff - headrest mouted screens / roof mouted screen / OBDII / GPS / dual audio cards.
    Panda
  1. Australian Ford XR6Turbo car pc
    By stimps in forum Show off your project
    Last Post: 06-13-2006, 04:23 AM
  2. Brick/Black Infiniti BA
    By contaygious in forum RR Skins
    Last Post: 07-27-2005, 06:49 PM
  3. Millenium Falcon
    By bosstone74 in forum Off Topic
    Last Post: 07-30-2003, 12:37 AM
  4. Replies: 4
    Last Post: 06-16-2002, 04:26 AM
