Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: BA Falcon
    Newbie jaytyn's Avatar
    Oct 2005
    Melbourne Australia
    BA Falcon
    Has any Aussies actually managed to install an LCD in the BA? Damn its a crap dash to try and get anything into!!
    Mine is the stock BA that does not have the colour LCD as pictured (otherwise I would use that).
    I am thinking of mounting the LCD on a bracket next to the existing screen (not overlapping the airbag) OR just on a bracket OVER the old screen..
    Any other thoughts our suggestions would be appriciated!!
    BTW the entire centre console is a complete unit, and the integrated radio cannot be removed. the screen also shows the Heater and Air Con settings! (does not really worry me if I cannot see them - I know if the AC is on or off
    Dec 2003
    http://www.asllogistics.com/ford_upgrades.html
    this place does upgrades from the factory crap LCD up to premium colour one, nice and expencive though
    I want to know if u got the control module for the colour LCD, could u scrap the factory LCD and bog in a lilliput screen or something into the dash
    Effectivly letting u keep all factory radio/aircon controls and display, but on a larger display with the added bonus of possibly touchscreen for a mp3 computer
    Newbie bob^'s Avatar
    Jun 2005
    Geelong - Australia
    Thats what I made for my Lilliput when I had it. Although I binned the lot and just went for an aftermarket deck to do DVD and MP3. I plug in the laptop to the factory screen for nav.
    2004 Ford Falcon XR6
    FLAC djmickyg's Avatar
    Feb 2004
    a mate from work with a Ba bought a spare center plastic bit from asl and choped out the screen bit and relocated it down the bottom and installed the liliput where the factory screen is... seems to work real well.. (i havent seen the final result yet),
    but that involves cutting and extending about 60 wires..
    Ive got a BF and im not going to cut any wires JUST YET so im planning something like bob^ has done..
    BOb^ why did u bin it? what was wrong with it down there?
    Dec 2003
    dkmickg: can you get pics of the setup, as its what i am thinking of doing
    I dont mind extending wires
    I dont have the factory screen and i sure as hell dont have 1100$ to upgrade to a halfassed LCD :P
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Is there anyway take the data from the screen and feed it to the pc, then install the lilliput in where the screen used to go so that the PC controls the HVAC / radio functions? I remember someone talking about the inputs to the factory screen and how they might be able to recreate the functions on a PC and LCD screen. Just a thought.
    Dec 2003
    Ive mentioned this a couple of times, since the base model uses a simple segmented LCD there SHOULD be a pin for each segment.
    So say you want to display the volume bar on Liliput LCD via a PC, there are say 10 segments, all of them light up for 100% and 1 for 10%, so thats 10 pins going to the LCD. If you used a USB/Serial box that wired into those 10 pins you can get each pins status via software, the screen overlay is just a little bit of programing away. I dont think this could be done with the colour screen.
    What i would like to try with the color screen, would be to send the output from the ICC that drives the LCD, to an aftermarket LCD. That way you have the nice fancy factory colour display, with high res VGA, s-video and a larger LCD. I belive this is possible as apparently when the Sat nav/DVD mods are in use it grounds vsel pin and according to what ive read it bypasses the ICC completly and goes straight to the screen. What this means is it may be possible to take the signal from the ICC that drives the LCD and feed it into an aftermarket one like ive said above - My idea here is that since it bypasses the ICC, the ICC must also generate a NTSC/60hz signal to feed the display rather than being intergrated (which is still possible)
    This is all speculative though, ive gotta wait 6 weeks till i get my BA, to pass the time ive been doing plenty of research ;D
    The easiest idea ive heard to get a 7" LCD in the factory position is relocate the screen to the tissue box as said above, which is all i might do. As getting a new ICC module to drive a colour LCD will be expencive and im not even sure my idea will work :/
    Phill
    Jun 2005
    Geelong - Australia
    I was going to buy one from ASL to remove the stereo component of it completely and then integrate an aftermarket headunit into it. $1300 put me off the idea, and I'll stick to the headunit mounted under the ICC.
    djmickyg - I binned it(literally) because for what I wanted the carPC mainly for(mp3s and the occasional movie), it made more sense to buy an aftermarket deck. Ended up with an Alpine DVA-9860 that plays DVD's as well as MP3 off DVD. It's much easier and quicker to use than a carPC(boot times etc) and I wasn't happy with the way some of the front ends worked occasionally(read: I couldn't figure them out)
    My composit to RGB converter has 2 video inputs, and I use one of them for the laptop( I need to buy another GPS receiver though, because I sold mine). It comes up okay once you increase the font size, etc. It's not the best, but hey, it gets you out of them difficult situations!
    Some pics of my setup
    I've also started developing a patch for the BA steering wheel controls to run the Alpine deck. It's all breadboarded up, just need to lay out a PCB for it.
    Jun 2006
    Mt Isa Qld
    Hi im new to this stuff i want to install a dvd player into my XR6 BA i have only got the base ICC would it be possible to install an alpine unit with a motorised screen into the tissue box if so could anyone give some ideas how to wire and install thanks
    Low Bitrate Pandaman72's Avatar
    Jan 2006
    Central Queensland, Australia
    Quote Originally Posted by bob^
    Bob,
    What converter do you have, I am struggling to find a Video Card that is compatible with the ICC screen, so I will just have to shell out for a converter box. This is what I get
    Thanks,
    Panda
    Car - Ford Falcon XR6 Turbo, footwell lights, Pioneer front speakers
    Carputer- P3 966MHz, 256MB RAM, 200GB HDD, 300W PSU
  1. Australian Ford XR6Turbo car pc
    By stimps in forum Show off your project
    Last Post: 06-13-2006, 03:23 AM
  2. Brick/Black Infiniti BA
    By contaygious in forum RR Skins
    Last Post: 07-27-2005, 05:49 PM
  3. Millenium Falcon
    By bosstone74 in forum Off Topic
    Last Post: 07-29-2003, 11:37 PM
  4. Replies: 4
    Last Post: 06-16-2002, 03:26 AM
