Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 93
Thread: Any Ideas on a 91 Suzuki Vitara Dash install?
  1. #61
    Constant Bitrate munkynpunky's Avatar
    Oct 2005
    Norwich UK
    urm, i have a soldering iron and solder lol?
    Car is Dead, Hand is burnt - Let that be a lesson to me! never open the bonnet when you smell burning.
    http://www.digital-car.co.uk
  2. #62
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Get some flux , you will come here telling me you love me once you use ()
  3. #63
    Oct 2005
    Norwich UK
    lol, ok trip to maplin in the morning... I have kinda hashed up this one...) It looks like the little siver circle in the green circuit board has come away with the solder i removed. I just have a brown circle like wood effect, no silver connection... hmmm, can i just dab solder back over it and it will work?
  4. #64
    Oct 2005
    Norwich UK
    guess this is what i need? http://www.maplin.co.uk/Module.aspx?...3849&doy=30m10
    What does flux actually do? Do i use it before i solder or after?
  5. #65
    Dec 1969
    Quote Originally Posted by munkynpunky
    Flux is acid paste, it helps metals bond together (and it works wonders).
    Once the silver circle is gone its done for, unless yo ucan follow where tje trace leads and solder at that place.
    Practice soldering on that dead mobo , and soldering wires together.(once you egt the flux).
    First you put the flux ( take it with a toothpic, not with your hands its acid ). Than put it on the wire or connection , take the solder and put it on the tip of your iron until it gets silver. Than put the soldering iron on the wire or connection. Dont put it too long , the components are sensitive to heat.
  6. #66
    Dec 1969
    THis is flux : http://www.radioshack.com/product/in...entPage=search
    Its usually a green or yellow paste in a container.
  7. #67
    Oct 2005
    Norwich UK
    ah ok, i've found Rosin Flux Dispensing Pen - aparently instead of using the toothpick I can just draw on my wires
  8. #68
    Dec 1969
    Some solder already contains flux, but theres not much.
  9. #69
    Oct 2005
    Norwich UK
    A lead free alloy solder containing a non- corrosive flux. This solder is 4% Silver 95.5% Tin & 0.5% Copper. We recommend this solder for use with the iron-clad and nickel-clad bits supplied with our soldering irons. Solder is available in 1mm 100g, 250g & 500g reels. The high Silver content improves the conductivity of the solder & lowers the melting point, improving the flow.
    This is direct from the maplin site for the exact solder i am using
  10. #70
    Dec 1969
    Thats not good , you need 60/40
    Tin does not conduct.
  1. Audi A4 install - LCD finally customed into dash
    By brrman in forum Show off your project
    Last Post: 10-07-2003, 11:47 AM
  2. Install in dash with no case?
    By tigerarch in forum General MP3Car Discussion
    Last Post: 03-15-2003, 12:18 AM
  3. Audi A4 Dash Install Pics
    By surfer6262 in forum General Hardware Discussion
    Last Post: 08-07-2002, 04:14 PM
  4. Dash Install help!
    By detz in forum General Hardware Discussion
    Last Post: 06-27-2002, 11:32 AM
  5. Preview of my in Dash LCD install
    By Destin in forum General MP3Car Discussion
    Last Post: 01-27-2001, 11:48 AM
