Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Help - problem with SEM bumper repair
    Nov 2005
    Unhappy Help - problem fabricating bezel with SEM bumper repair
    Is the Dynatron bumper repair product better than the SEM version? I ask because I just got most of the way through fabricating a Lilliput bezel into a flat sheet of 1/8" ABS and had one of the seams separate after the SEM bumper repair had cured for > 24 hours. Then with only a minor amount of force, I was able to pop out the entire bezel from the opening in the ABS. It seemed to separate from the ABS sheet just as easily as from the Lilliput bezel. I had sanded the bezel down to the raw plastic and had filed the edges of the ABS as well. I should have guessed there would be problems when the cured material flaked off of the surface of the ABS fairly easily while sanding.
    Can I expect better results from the Dynatron? Also, is there a product that has a little more working time than the SEM? It seems like I only get around 3 minutes before it has set up enough so that it won't flow into seams anymore.
    If not, it sounds like the dissolved ABS will do a better job assuming a thick enough solution.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    You should NEVER use filler material as an adhensive.
    By that I mean, you should epoxy the Lillipt and the bezel before using SEM bumper repair. That is how I did it and didn't have any problem.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Oct 2004
    NY
    the sem product is more of a filler... it is soft & easy to sand, but not really good enough to bond the bezel to the panel...the adheasion isn't that hot with the sem also.... dynatron is closer to an epoxy of sort & will do the job a lot better, still wouldn't be a bad idea to weld it first... or plastic epoxy...., but the dynatron stuff is pretty strong all by itself.. it should do the job......
    Nov 2005
    Thanks for the advice. I had thought the SEM product was equivalent to the Dynatron, but now I know. And I had thought it was good enough to work as an adhesive as well based on turbocad6's post (#247) in the "Solvent adhesives..." thread. There is a quote there "use this stuff as glue to final position bezel" referring to the Dynatron bumper repair kit that led my to my original plan.
    So I'll try to find the Dynatron bumper repair tomorrow (or 3m or equivalent).
    With the SEM bumper repair, I ended up with a few small pinholes that I was in the process of filling when I ran into trouble. Will I likely experience the same with the Dynatron? If so, can I fix them with just the bumper repair product, or should I look into a spot putty? Any brand recommendations for that?
    Thnaks again for the help.
    Sep 2003
    Beach City, Socal
    You are more likely to run into pinholes. I use bondo brand (lazy to find something else) spot putty, and it works fine.
    When you apply filler product, try to use a razor to smooth it out to reduce pinholes and less sanding.
    Aug 2005
    Quote Originally Posted by MatrixPC
    Just be aware that spot putties (the kind without a cream hardner) will shrink and can potentially cause cracking around where it has been applied. Usually if you use it in small area's, for instance, just to fill pinholes, you're fine. Just don't get to crazy with it. That's what the regular fillers are for.
    In the works...
    Dell GX240 SFF
    P4 1.8GHz, 256 RAM, 160GB HDD
    8" Lilliput (fab work completed - F-150)
    My worklog
    Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
    Nov 2005
    So after calling around to every auto body supply store that I could find and nobody carries the Dynatron Flexible Bumper Repair kit or the 3M product. However I did find some Transtar Plasto-Mend Plastic Repair (Flexible). It looks similar to the Dynatron and claims the following:
    Plasto-Mend plastic repair is an epoxy material designed for cosmetic repairs of flexible to rigid parts such as ABS, TPO and Polyurethane. Provides maximum adhesion and superior featheredge sanding qualities.
    It claims it can be sanded in 15 minutes.
    Anybody have any experience with this product?
    Oct 2004
    NY
    no clue..... "epoxy material" sounds promissing..... "designed for cosmetic repairs" might indicate low structural strength though.... ?????????????
    Jul 2005
    Does anyone know if there is somewhere online where you can buy the dynatron stuff?
    1997 Mustang GTS "Jenna"
    VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
    Jul 2005
    Quote Originally Posted by Miles
    Nevermind - thank you ebay
  1. Solvent adhesives... why don't more people use them?
    By coachreed in forum Fabrication
    Last Post: 10-19-2011, 05:55 PM
  2. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  3. Sproggy Psu Problem
    By 480TURBO in forum Power Supplies
    Last Post: 11-22-2004, 01:58 PM
  4. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 09:58 PM
  5. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 09:27 PM
