Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Plastic molding on a budget?
  1. #21
    Feb 2009
    I have here some information about guide in plastic molding process, i research this in some site of google that are related topic here... Hope you will like it guys...
    The Plastic Molding Processes:
    1. Injection Molding: In Injection Molding, melted plastic is forced into a mold cavity. Once cooled, the mold can be removed.
    2. Blow Molding: Blow molding is like injection molding except that hot liquid plastic pours out of a barrel vertically in a molten tube.
    3. Compression Molding: In this type of plastic molding, a slug of hard plastic is pressed between two heated mold halves.
    4. Film Insert Molding: This plastic molding technique imbeds an image beneath the surface of a molded part. A material like film or fabric is inserted into a mold. Plastic is then injected.
    5. Gas Assist Molding: Also called gas injection molding is used to create plastic parts with hollow interiors. Partial shot of plastic is then followed by high-pressure gas to fill the mold cavity with plastic.
    6. Rotational Molding:
    Hollow molds packed with powdered plastic are secured to pipe-like spokes that extend from a central hub.
    7. Structural Foam Molding: Structural foam molding is a process of plastic molding usually used for parts that require thicker walls than standard injection molding.
    8. Thermoforming: In this plastic molding process, sheets of pre-extruded rigid plastics are horizontally heated and sucked down into hollow one-piece tools. When the hot plastic solidifies, its shape conforms to that of the mold.
    Plastic Industry
  2. #22
    Dec 2005
    Raleigh, NC
    There are new SLA (stereo lithography), SLS (selective laser sintering) and deposit based methods which have come a long way in the last 2 years. Again, the catch is you need CAD and reverse engineering of the original object if you want to make a new one. It's easy to do if you have a 3d scanner and the software though
    The printing cost is all determined by how much raw material is used. You can even color the object so when completed it just needs clear coating for protection.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
  3. #23
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by shadow0000 View Post
    Actually, blow molding is more like gas assist molding. A cylinder of plastic is extruded and descends between the parts of a mold; the mold closes and air is injected into the cavity to force the cylinder out to conform to the chilled mold. It's the way a lot of pails and bottles are formed.
    Quote Originally Posted by ik632 View Post
    These SLA and SLS systems are really coming along. They're relatively slow (although that's likely to change), and are probably best -- right now, anyway -- for low-production uses and prototyping. That makes them absolutely perfect for the sort of work we do in carPCs because almost everything we do is a single unit or a very small number of units.
    ik632 -- it appears that you're working in this area; what's your take on this?
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  4. #24
    Dec 2005
    Raleigh, NC
    Between SLA and SLS it's a tough call. I actually called a friend today to have him send me samples of the different materials that you can use. There's a new PP and ABS for SLS that looks promising for parts for the car. The materials for SLA are good as well and there's a PP and ABS like material as well. The specs for the materials used in SLA and SLS are pretty close so it would come down to the surface finish. I think the SLA might be a little smoother but I can't say for sure before I see the samples.
    As far as speed goes I'm not all that worried about it. Anything that we're going to do would be completed in one shift. You could technically have it started at the beginning of a shift and shipped that same day so if you're really in a rush you'd end up paying for making the shop move the schedule around. I know a few places that I work with that will do pretty much any rapid prototyping type of print. I just need to send them an STL of the model.
    There's one material that is used in both the SLA and SLS that feels like PE at certain thicknesses, like PP in others, and like ABS in others yet. I think that material has some flexibility and comes in black. I hope that I like the way it feels because the specs make it sound just about perfect for the car applications. The temp range would even handle the cold and hot.
  5. #25
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    We recieved some samples a couple months back that had different strengths. Easy to hard on the flexability. Ours started a yellow/orange clear plastic. But currently we have a cheaper manilla color plastic.
    The top of SLA parts are really smooth. The bottom will be bumpy due to the way the SLA machine builds up the plastic. It needs supports to build onto so you get a honeycomb support structure. Once the part is done the supports can be removed and the part cleaned. However, for our carputer applications the part will probably still need a little sanding and finish paint.
    So FYI: if you have a part made this way and you want one side smooth make sure you let them know to build it with that side up. If its a curved surface you will still need to sand it even.
    check my older post of a bezel made with SLA
    S-10 Install,In progress,baby steps,first rip apart dash :)
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  6. #26
    Sep 2009
    I'm always used plastic molded materials. For curiosity is there a parts in making plastic molding which include the operation of automated insert molding production cells for high volume low cost production of sub-assemblies? Maybe Technology is one of the core values that make an area of precision molding which many customers recognize.
  7. #27
    Dec 2005
    Raleigh, NC
    Quote Originally Posted by Mike38 View Post
    _________________
    Rapid prototyping
    Have you seen the printers that have multi durometer materials? You typically have a white and black (one is really soft and one is hard) and then when you print they can make a mix of 100-0 to 0-100 of the two. It still has a support mechanism so you really have 3 canisters in the machine. Curing is done with UV light. I have their brochure sitting on my desk as I talked to the guy a few weeks ago. Stuff looked pretty good. Much better quality than FDM and about similar to SLA. Also, more durable than epoxy/sand, but you can't really do much more than gray scale, so you are stuck with sand if you want color for architecture.
  8. #28
    May 2010
    Cool tapplastics
    I've been vacuum forming protoype parts with styrene.Then I coat the styrene with polymer clay...."Magic Sculpt" to make parts.
    I made my vacuum former from a desk drawer and Peg board.
    I live in San Francisco Bay area and my favorite store is http://www.tapplastics.com
    Tap Plastics demo's can also be seen on youtube.
    There is an Oregon store near you
  1. Plastic Weld?
    By slboytoy in forum Fabrication
    Last Post: 08-31-2006, 11:51 AM
  2. What do i use to bond PP plastic and Xenarc case?
    By Will Albers in forum Fabrication
    Last Post: 07-15-2005, 09:06 AM
  3. plastic reinforcements (kickpanels/speaker baffles)
    By therussman2002 in forum Fabrication
    Last Post: 06-23-2005, 11:00 PM
  4. Help With Sanding and Painting Interior Plastic
    By xhazn in forum Fabrication
    Last Post: 05-06-2005, 07:18 AM
  5. best plastic adhesive/filler?
    By sohr in forum Fabrication
    Last Post: 06-22-2004, 01:28 PM
