Results 1 to 4 of 4
Thread: Suggestions?
    Jul 2005
    Suggestions?
    Ok i have no cup holders in my car, so before doing my carputer im going to attempt that
    Basically what i figured i would do is make the holes for cup holders like the rings they give u with speakers, and attach them to the side with round piece of wood like the guy at
    http://web.njit.edu/~cas1383/proj/Glassing1/index.htm
    and basically do the same thing for both cupholders and the hole for the Gear switch... and then put fleece over that and fiberglass it all?
    does that seem like it would work or what??
    Here are some pics of what im working with (AND YES I KNOW I HAVE THE STUPIDEST DASH EVER MADE)
    inside1.jpg <--inside of car
    insidecar2.JPG <--inside of car
    insidecar3.JPG <--inside of car
    insidecar4.JPG <--inside of car
    insidecar5.JPG <--inside of car
    factory1.JPG <--facory piece
    factory2.JPG <--facory piece
    Jul 2005
    None
    Low Bitrate yamathegreat's Avatar
    Aug 2004
    calgary, alberta, canada, cold
    if im understanding what you want to do it should work fine also if you dont want the cupholder enclosed you could make it more like a cup holder you would find on a boat the ones with the circle cut out and another circle cut out below but still opem it would make it a lill easier to fiberglass although im not sure how it would look also what size cup holder are you looking at? you could also check out canadian tire or if your from the us im sure you have simular stores where you could buy an aftermarket cupholder for 6$ or so and just glue it to the project and then fiberglass or bondo over to make it look as stock as youd like
    Jul 2005
    i could buy an aftermarkey one but i cant find any that would fit in that area as i have limited space
  1. Suggestions for PC Parts?
    By mattwz in forum Newbie
    Last Post: 06-09-2005, 07:59 PM
  2. Suggestions for carputer foundation
    By jdolf in forum Newbie
    Last Post: 03-15-2005, 01:22 AM
  3. suggestions
    By Jaimz in forum Power Supplies
    Last Post: 09-28-2004, 05:08 PM
  4. hardware suggestions please...
    By autophile in forum General Hardware Discussion
    Last Post: 09-04-2004, 09:56 PM
  5. Replies: 9
    Last Post: 08-26-2004, 08:59 PM
