Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: My 1st bezel fabrication for E39
  1. #11
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    This is all I could find.
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
  2. #12
    Newbie gabureiru.'s Avatar
    Jan 2006
    what did you used to blend together the display with the dash???
  3. #13
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    I used superglue to attach screen frames and radio bezel together.
  4. #14
    Mar 2005
    Seattle Area
    I used duramix 4040 and 4056. If I was to do it again, I'd just use 4056.
    Here's a tip if you're curious. Cut a hole in the bezel slightly larger than the screen you're trying to mold in. Cover the front side with masking tape and then position the screen in the hole. Now fill in the gaps with whatever type of filling agent you plan to use (bondo/fiberglass/duramix) Once it dries peal the masking tape off and you'll have a flush surface. With Duramix, if you do it right, you won't even have any shallow spots to fill in.
    Here's why I chose Duramix
    Pros:
    - Fast dry to sand time of only 5 minutes
    - it is plastic, so no surface transition to worry about.
    - smooth solid surface when dried
    - very liquid at first so it can easily fill small cracks
    Cons:
    - Expensive ($40 a tube)
    - New tip needed each time (tips aren't expensive... but still)
    - work time of only 60 seconds
    Matt Atkins
    '98 540i-6 blk/blk
  5. #15
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    Today I sprayed some filler over the bezel and checked how it looks. I also took some new photos. As you can see I still have some work to do.
  6. #16
    Mar 2005
    Seattle Area
    Wow, looks good!
    Matt Atkins
    '98 540i-6 blk/blk
  7. #17
    Low Bitrate cpjolicoeur's Avatar
    Boston, MA
    coming along great
    STATUS: Planning / In Progress / Completed
    COMPLETE: [*********] 100%
    CAR: '02 Mitsubishi Lancer OZ Rally
    SYSTEM: EPIA M10000
    GPS: HaiCOMM 303e GPS, Routis 2004
    DISPLAY: 7" Xenarc 700TSV
    POWER: OPUS PW-70a + ITPS Combo
    MISC: DVD, WLAN
  8. #18
    May 2005
    a small question...i have a e39 and would like to have a go at this...i have a bezel wich i woul transform :
    when i measure the bezel it has a hight of 12cm...but when i look at all available touchscreens (xenarc, lilliput, etc) they all measure 12.5 and upwards...
    how does this work the to integrate the front panel of the touchscreen in the bezel? or are the measurements they give on the box not right?
    thanx
  9. #19
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    I think that the measurements are incorrect. You can use that bezel but you have to cut your screen frame just as I did. You can also use bondo to increase the height of the bezel. Your radio bezel is too short anyway to fill the hole that orginal cd+midi leaves.
    I ordered orginal radio flap and the plan is to integrate that flap into bezel. Let's see how it looks.
  10. #20
    Mar 2005
    Seattle Area
    Yes, I had to extend mine as well to fit the entire gap.
    Matt Atkins
    '98 540i-6 blk/blk
  1. Replies: 58
    Last Post: 05-14-2009, 10:21 AM
  2. GOLF V & Touran 7" Bezel Xenarc Germanfreaks
    By Janus in forum Fabrication
    Last Post: 07-16-2008, 04:24 PM
  3. Xenarc 700TSV / custom e46 bezel mounting
    By zaid175 in forum Fabrication
    Last Post: 06-13-2005, 07:05 AM
  4. Bezel fabrication
    By greenwire in forum Fabrication
    Last Post: 04-18-2005, 05:13 PM
  5. Replies: 35
    Last Post: 01-12-2005, 02:10 PM
