Results 21 to 30 of 39
Thread: My 1st bezel fabrication for E39
  1. #21
    May 2005
    Quote Originally Posted by BCN
    I think that the measurements are incorrect. You can use that bezel but you have to cut your screen frame just as I did. You can also use bondo to increase the height of the bezel. Your radio bezel is too short anyway to fill the hole that orginal cd+midi leaves.
    I ordered orginal radio flap and the plan is to integrate that flap into bezel. Let's see how it looks.
    no, this bezel is just the right size to cover the original cd...it is about 2 cm higher than the one you worked on...a perfect fit.
    all i have to do is enlarge the hole.
  2. #22
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    Maybe those measurements are for the frame...not for the screen?
    So you had to remove the flap to get radio bezel fit?
  3. #23
    Jan 2006
    Today I sprayed some filler over the bezel and checked how it looks. I also took some new photos. As you can see I still have some work to do.
    I'm in the process od sanding down the bondo on my bezel, and was wondering about the "filler" you used. What exactly is it?
    TIA,
    - Dan
  4. #24
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    Filler is sprayable bondo ( polyester filler ). After you have sprayed it you have to sand it down in order get smooth surface. I can't remember the brand but I can check it for you.
  5. #25
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    Ok, I checked the spray can and it's Motip Filler.
  6. #26
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    I got my "flap" today and lined it with tape. When I have time I'm going to cut and shape the flap so that it fits to the bezel.
    Because of my ****ty english ....here you have a pic in order to get the idea.
    Tape is there just for helping me to cut straight lines.
  7. #27
    Jan 2006
    Thanks for the information!
    - Dan
  8. #28
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    Small upgrade....it is still not ready but I'm working on it
    Sorry for the picture quality I used my mobile phone camera.
  9. #29
    FLAC sama's Avatar
    Feb 2006
    London, UK
    very nice work dude, I like it very much. I completed my e39 bezel recently too, check it out
  10. #30
    BCN
    BCN is offline
    Newbie BCN's Avatar
    Nov 2005
    Tampere, Finland
    Yours look great too
    I would like to see more of E39 bezel fabrications but there are so few.
  1. Replies: 58
    Last Post: 05-14-2009, 10:21 AM
  2. GOLF V & Touran 7" Bezel Xenarc Germanfreaks
    By Janus in forum Fabrication
    Last Post: 07-16-2008, 04:24 PM
  3. Xenarc 700TSV / custom e46 bezel mounting
    By zaid175 in forum Fabrication
    Last Post: 06-13-2005, 07:05 AM
  4. Bezel fabrication
    By greenwire in forum Fabrication
    Last Post: 04-18-2005, 05:13 PM
  5. Replies: 35
    Last Post: 01-12-2005, 02:10 PM
