Results 1 to 10 of 11
Thread: Replacing Dash Piece: Fiberglass or Wood?
    Sep 2005
    Pomona, CA
    I'm replacing a piece of my dash that will end up being a hinged cover (I hope) for my motorized screen. I'm guessing that fiberglass would be lighter and therefore more desirable because I want to use the smallest motor possible. If I used fiberglass, how would I go about making a duplicate piece? Would I tape it and put foil on it and apply fiberglass on top of that and that would be it (as I've seen in tutorials), or what? I've never used fiberglass before, so I don't know...
    Here's what it looks like - it's fairly flat with two holes for the air vents:
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    Constant Bitrate blacklancer's Avatar
    Nov 2005
    Los Angeles, Ca
    i'm no expert, but why don't you cut the piece you want out of that piece, add some material behind it for strength and call it a day. that way it would be the same material and look nicer. just an idea.
    Sep 2005
    Pomona, CA
    Yeah, I don't want to cut it - for now I'd like to leave it intact, just in case...
    Carputer Progress:
    Teardown PC [100%]
    Nov 2005
    Los Angeles, Ca
    its always a good idea to pick up a spare. you could try a junkyard near you, or call the dealership. then you can cut into one and play around with it.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Junkyard spare and cut the piece out of it.
    Want to:
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    RI
    Man up and hack up the original. That's what I'm doing right now.
    FWIW though, I don't have the cash to go pick up a new one, or else I would.
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
    Sep 2005
    Pomona, CA
    I guess I'll ask the service guy tomorrow when I get my brake pads changed; Mazda 3 brake pads have bad squeaking problem
    Carputer Progress:
    Teardown PC [100%]
    Oct 2005
    Connecticut
    boo, man up and do it yourself!
    Sep 2005
    Pomona, CA
    I meant about finding another of the same piece...
    Carputer Progress:
    Teardown PC [100%]
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    just glass it it will be easier and it will be lighter... all u gotta do is wrap that ***** in tin foil and lay like 2 layers of matt on it and then pop it off pritty basic just check out some fiberglassing websites
  1. Holding my LCD into my custom dash piece
    By Grayscale in forum Fabrication
    Last Post: 07-19-2004, 10:19 PM
  2. any tips on building this guy IN
    By BOND007BE in forum Fabrication
    Last Post: 06-17-2004, 12:42 PM
  3. Non-permanent fiberglass mount
    By Chairboy in forum General Hardware Discussion
    Last Post: 03-21-2004, 04:33 AM
  4. Mounting the LCD inside the dash?
    By XxAndyxX in forum Newbie
    Last Post: 01-16-2004, 04:51 PM
  5. wood dash materials
    By infinitiqx4 in forum General Hardware Discussion
    Last Post: 06-17-2002, 10:32 AM
