Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 62
Thread: Plexi/Plastic Gurus :-) fabricating headlights
  1. #21
    Oct 2005
    Hou. TX
    I have some experience in custom making headlights, no expert though.
    If your bike currently has a glass lens over both lights, then I would suggest using those. Then focus on mounting the projectors in there.
    If you were going to replace the lens you would want to use polycarbonate. It is similar to plexi, but much stronger and has a higher melting point. Poly can withstand about 350*F which should be plenty. You would want to get a sheet and lay it on the glass and put it in the oven (gas oven) at about 250*F to start and see if it get's soft. You nmay have to go up in heat a little, but 350*F will cause it to form bubbles and ruin the piece. Once it is shaped you will need to cover the exterior with a protective film to keep it from scratching.
    Trust me, You will be much happier with the real glass.
    The factory housing you have should be vented as well as filtered to keep dust out and to let the air breath a little. Find that vent so we know what were dealing with. Sometimes it is a rubber tube and sometimes a special sticker that breathes.
    You will want to retain the factory adjusting mechanism as well.
    I would recommend you mount both projectors by cutting the stock reflector so that the projectors reflector housing sticks out through the rear. The bulb and lens area will need ot be sealed up in the front portion. I would recommend one projector to be the low beam (with HID bulb if possible) and the other projector (high beam) can be modded by removing or reshaping the cut off shield so that the beam projectos higher. You will want a regular bulb for the high beam.
    I hope that helps. Let me know if you need more info or pics. I think I have some pics of a bike with a HID projector conversion. Make sure you have good projectors before you waste your time and money though.
  2. #22
    _
    Mar 2004
    Little Elm, Texas
    lets see some pics of your chicken strips....if you're so worried about saving weight
    or do you drag this bike?
    Jan Bennett
  3. #23
    Low Bitrate Daley's Avatar
    Oct 2005
    H-Town
    What about the concern of changing a dead bulb?
    To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
    If it's not fun, you're not doing it right!
  4. #24
    Oct 2005
    Hou. TX
    Quote Originally Posted by Daley
    What concern. Access should be the same.
    If you mean the modded H9 bulb, buy another one, go home and remove the burned out one. Cut the new one with metal snips just like the first one and install it. It's not the end of the world.
  5. #25
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    nice advice jason thanks! well what im doing is im going to keep the glass and im fiberglassing the front bezel for the projectors thebike will be done by next week :-)
  6. #26
    Dec 2004
    finshed :-)
    ^^ my dogs knocked the hell out in the garage while im working on my stuff
  7. #27
    Dec 2004
  8. #28
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    ^^^ Good ****. I like it.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  9. #29
    Dec 2003
    that looks great, good job. post some pics of them on once you get the wiring done.
  10. #30
    Dec 2004
  1. Replies: 7
    Last Post: 01-24-2007, 10:31 AM
  2. Making Projector Headlights!
    By nFiniteTuning in forum Fabrication
    Last Post: 02-02-2006, 09:25 AM
  3. Calling the Forward Converters Gurus - Please Help !!
    By Zznakie in forum Power Supplies
    Last Post: 10-20-2004, 02:11 PM
