Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: New Aluminium Case Moving Along Nicely
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    This is REV B of my carputer. I added an OPUS 150 and got rid of the inverter. This saved alot of space so now I can make a smaller case. I got a hindged door with a lockable latch. All the inputs are bulkheads for easy install/removal. I got a 9 pin molex for all the power and rca bulkheads for the audio. It should be in production by the end of the week. I'm gonna take pics all through the process. First it will be laser cut and deburred. Then it will go off to the brake forms. Next it goes to assembly where the clinch nuts and standoffs will be pressed in. Next the hindge will be spot welded to the door and the case. Then it will go off to the paint booth. And finally, I will do all the final assembly.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Lookin good man! What application are you using for design? Im working on a similar project in another thread. This looks to be almost a full size ATX case though. I used .063" aluminum on mine and it is strong as can be. I would not do anything under .040" or it will be too flimsy. Can't wait to see some pics of the production and final model.
    Oct 2004
    I'm using .050 H32 so that I can use an .032 bend radius. What bend radius did you use? Its a micro atx case. Not quite as big as the ones in the stores but it will house full size PCI cards. It's a lot thinner than and shorter than a normal case not to mention single walled design to save space. It's a bit longer because I'm puttin my USB sound card and XM PCR all in the case. The software I used for this is Mechanical Desktop 2004 DX. I have Catia and Solidworks but for such simple geometries its easier for me to use MD. How about yours?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    The pieces are being cut today on either this laser or the dual bed laser similar to this one.
    Mazak Laser Capable Of Cutting Up To .250
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    Tomorrow the pieces will be break formed on this with an .032 radius.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    Here are all the pieces, laser cut and waiting to be break formed.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Newbie gabureiru.'s Avatar
    Jan 2006
    Awsome!!!! which I had access to that kind of machinery. Good work, please keep us updated
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    yo man ur near by if u finish this caser i might be interested in buying em maybe bulk status
    Oct 2004
    Break formed. Now it's off to assembly.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Oct 2004
    primed in military spec primer.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. suggestion for a case for OPUS 150w (boxed)....
    By Maskone in forum General Hardware Discussion
    Last Post: 07-29-2005, 12:40 AM
  2. FS: Opus 150W, 60GB HD, Sereniti case
    By aoLhaTer in forum Classified Archive
    Last Post: 01-30-2005, 04:38 AM
  3. New system, CASE reccomendation
    By septicdeath in forum General Hardware Discussion
    Last Post: 01-29-2005, 05:56 AM
  4. A-Tech 5000 HP Media Center Case
    By Giuliano in forum General Hardware Discussion
    Last Post: 12-30-2004, 11:27 PM
  5. need opinions on a mini-itx case
    By a17_track_350z in forum Newbie
    Last Post: 01-27-2004, 02:15 PM
