Results 1 to 10 of 17
Thread: Removing wrinkles in paint
    Constant Bitrate doublet's Avatar
    Aug 2005
    OKC, Oklahoma
    I've messed up my painting job. Some parts are absolutely perfect but some have wrinkles on them after the paint dried. How do I get rid of these? I've tried sanding and repainting but I can't seem to get rid of it. Should I just use paint thinner and start all over? This might be a stupid question, but would paint thinner remove the primer? I sprayed in two directions, vertically and horizontally. Is that the cause of wrinkles?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    paint thinner and start all over, make sure to properly coat with plenty of primer....and make sure the surface is very clean.
    PC Components:
    My work log
    Aug 2005
    OKC, Oklahoma
    What kind of thinner should I use that's safe on plastic?
    Dec 2004
    Maryland
    depending on what kinda paint you used, you might be safe with just using nail polish remover
    PC Components:
    My work log
    Jun 2004
    Bay Area, California
    wrinkles? you mean like the paint was coated too thick? those kind of wrinkles? kind of "drip" wrinkles?
    Low Bitrate dvwjettaiii's Avatar
    Jun 2005
    Neenah, WI
    If you're talking "Orange Peeling", you don't need to repaint it. Get some fine sandpaper and sand out the wrinkles and then use some rubbing compound to take out the sandpaper scratches. I did it when repainting my trunk of my car and it worked really well.
    Nov 2005
    Wrinkles??? Pics of any of them? If your painting plastics that have had "armor all" etc on them you have to prep it really well. Use "Plati-Prep"
    Safe on most plastics
    Aug 2005
    OKC, Oklahoma
    i tried to take some pic but i can't get a clear picture. it's not orange peel or drips. it looks like little hills, for a lack of a better word.
    Jun 2004
    did you use a can of spraypaint?
    Aug 2005
    OKC, Oklahoma
    yes, SEM spray can.
  1. SEM paint
    By Quattro in forum Fabrication
    Last Post: 04-09-2005, 03:00 PM
  2. Removing Solder Drips From Paint
    By wh0k in forum Newbie
    Last Post: 03-22-2005, 12:07 PM
  3. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  4. Removing Paint from Dashboard
    By Jimbo1978 in forum Fabrication
    Last Post: 12-24-2004, 04:02 PM
  5. Removing paint sucks
    By wizardPC in forum Off Topic
    Last Post: 07-01-2002, 02:23 AM
