Results 1 to 6 of 6
Thread: Recessed Screen Questions
    Variable Bitrate DaveB's Avatar
    Mar 2004
    Hi guys,
    This is day one of my build and I made GREAT progress today. I'll post a picture in a little bit. I'm going to hot glue the LCD in place temporarily for my photos.
    When you recess your screen do you normally leave the cover on the back of the LCD? I have an 8" Lilli.
    Is it necessary to put something under the bottom wood shelf (in the back) of the recessed frame that the LCD sits on?
    How do you guys finish the inside of the wood? Do you just prime it and paint it or is it necessay to wipe glaze on the inside before priming?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Mar 2004
    This is what my dash looked like this morning. Sorry that the dash is upside down on the desk.
    The center opening is where my HVAC controls were. I'll be moving them down to where the cubby hole is.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Mar 2004
    This is the recess frame I built for my 8" Lilli.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Mar 2004
    This is the frame from the side. It's cut top and bottom with a 10 degree angle so that the screen angles up to cut down on glare.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Mar 2004
    This is my LCD mounted temporarily in the dash with hot glue.
    I spent several hours enlarging the hole from the cubby hole so that it would hold the relocated HVAC controls. I used a bench top spindle sander to enlarge the opening. I found that a dremel was way too hard to use. The dremel would get away from me at times. Also, the dremel bit is so small that you can't really make straight lines with it. It was critical to me that the HVAC controls fit tight and look as factory as possible.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    damn that looks good dude nice fit in there too bring on the pics :-P
  1. How-To: Recessed Screen and DVD Drive
    By Altimat in forum Fabrication
    Last Post: 05-10-2010, 05:19 PM
  2. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  3. Replies: 4
    Last Post: 01-26-2006, 03:35 AM
  4. FS: IBM Thinkpad 1400, National Display Systems Screen
    By emailthis1 in forum Classified Archive
    Last Post: 10-02-2005, 03:02 PM
  5. Need touch screen advice
    By sciff5 in forum LCD/Display
    Last Post: 05-29-2005, 10:58 PM
