Page 15 of 78 FirstFirst ... 567891011121314151617181920212223242565 ... LastLast
Results 141 to 150 of 778
Thread: Complete bolt in Screen/CPU/HD/PS - indash
  1. #141
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by dirty06F150 View Post
    To clarify:
    Even though you are selling yours, the aluminum chassis are still for sale(~$65 shipped)?
    I hope Albatron releases their AMD754 mini-itx board soon, because that would be my perf combo, but this chassis is the clencher esp. since I have an 06 f150 with the Metra kit for an alpine anyway.
    Yes I am still in the fabrication business $65 via paypal will get you a chassis.
    Still no bites on the PC complete so in the dash it shall stay for now. Its been running really good. I have freedom 2.1 on RR running as my frontend. All flash. I may convert carpc version 2 to a media box for my living room. Either way I love doing this stuff.
  2. #142
    Jul 2005
    Motorcity
    Blog Entries
    1
    I am pulling this unit very soon to do some major revisions of the hardware and software. Im swapping out the super screen for a xenarc unit. Adding some FM support and completley redoing the software for more optimizations. May try a flash drive OS install. But def going with XP beast edition. Funny thing is there is nothing wrong at all but i just need to tinker.
  3. #143
    Apr 2005
    I think that you have done a fantastic job with this project. I am starting on a similar project for my Honda Element. I have the parts designed and am now trying to find sources to build the components affordably. I do not have easy access to a fabrication facility. Can you tell me if you know a source that does this kind of work at a reasonable price? I have the faceplate/bezel taken care of but I need to find a source to laser cut or water-jet cut the housing and then bend it to shape. I got a quote from one of the online prototype places and it was around $170. While probably accurate, that is rich for my blood. I would like to buy one of your units but the dash on the Element is tight. Yours would not clear all of the vents and cables that are in the back of the dash. Any help would be appreciated.
    BTW - I have all of the drawings and 3-D models complete in Solidworks format if you know a place that I could send them for a quote.
  4. #144
    Jul 2005
    Motorcity
    Blog Entries
    1
    Send me the drawing in .dxf if possible. If not send the solidworks format and i will see if i can open it. I will quote you on this but I cannot see it going more than 100$. I will give you a final quote upon seeing your sketches.
    Well I got 2 brand new 1Gb flash drives today. I mini SD and One a USB. I've been reading up on solid state media and booting an OS off of that. New setup will *most likely* have an EWF embedded XP install on 1GB flash drive. I will keep the 80 gig harddrive for mp3's, videos and map data. Im also wondering if I could hack IG3 to read maps off of a DVD disk. Then I could be OEM style, crusin along listening to the Tigers on AM, on a flashed OS, reading map data via DVD. Ill let everyone know how the Flahdrive'n goes
  5. #145
    Sep 2006
    The intarwebs
    is there a way to intergrate a dvd drive in there? (not in the glove box)
    Planning {[][][][][][][][][][]} 100%
    Funding {[][][][][][][][][][]} 100%
    Construction {[][][][][][][][][][]} 60%
  6. #146
    Jul 2005
    Motorcity
    Blog Entries
    1
    I could fit a slot load on top or bottom but I would need to make a custom trim kit. Ive been thinking about this though. I really have no need for a drive cause all my DVD's are ripped to .avi's anyway, but it would be nice to have. Im also working on putting a volume knob on the front of this unit. My main concern right now is getting XPembedded running on a CF card.
  7. #147
    Constant Bitrate john94587's Avatar
    Sep 2005
    Bay Area, CA
    Blk, Do you know if the Metra Kit will fit the Lilliput 619 7" screen??
  8. #148
    Jul 2005
    Motorcity
    Blog Entries
    1
    Yes, any 7" screen will fit the metra kit. Every screen will also require a little bit of trimming to fit. Good luck on your project!
    On another note I've been doing mad software config for a super fast, super small XPE install. Ive got an image im pretty happy with but im still working on it because i want it perfect for deployment. Im debating about waiting for deployment due to the number of new lightweight fast frontends starting to surface. Either way I got the hard part out of the way and that was configuring a windows install that never writes to the drive its installed on. Im still looking into a HQCT module also. If i get a hold of the radi omodule soon I can have a full functioning carPC that has no 'standard' harddrive. Everything will run from flash and It will have navi, cd, dvd, am, fm. The mp3's will be on another USB drive. Due to the size of the maps in IG3 ill only be able to put about 6-7 states of data on the flash. (unless I upgrade) Anyway having a great time with this hobby still. Im going to pull the unit out of my car for a week or two (and reinstall the 'blah' OEM radio) while I deploy the embedded OS and complete the new software. Im also upgrading the screen when its pulled. Heres that hardware i picked up today.
  9. #149
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well i think i may have the perfect XP image.
    Started with XP SP1
    102mb ISO generated.
    250 Mb TOTAL installed
    everything stripped including all drivers.
    only Newest drivers for my exact hardware integrated.
    RR set as shell.
    in Vmware im getting 15 second cold boots
  10. #150
    Sep 2003
    Oh man that is hot. What exact hardware are you running now and what drivers are you using if you don't mind listing them. Can't wait for you to get a final version of this!
    Nogaro 2000 Audi S4 (Stage 3)
    Black 2000 Audi S4 (Stage 1)
  1. indash touchscreen vga rca inputs
    By mike86ttype in forum Classified Archive
    Last Post: 01-30-2005, 10:30 PM
  2. FS: Indash Unit from tm-701L
    By BoraXP in forum Classified Archive
    Last Post: 01-15-2005, 03:48 PM
  3. Cheap indash monitor
    By darkhavoq in forum LCD/Display
    Last Post: 11-21-2004, 03:01 PM
  4. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 09:15 PM
  5. Nissan Sentra 1996 GXE Complete Project. 14'' Screen
    By criterzzz in forum Show off your project
    Last Post: 08-01-2004, 01:07 AM
