Are you going to be providing your OS image to those people interested and amazed at a 12 second cold boot !?!
which enclosures are we talking about? the double din one or the VIA etched one?
I installed my carpc into my pet Kangaroo, mate.
I could share my ISO i guess but its optimized for a via m10000, 7" touch, and MS USB GPS. Unless you have this exact hardware the image won't boot that fast.
do you have a pic of what would be shipped and a list of what can fit
I have M10000, m2atx, ocz ram ddr, & 2.5i. hdd also a laptop dvd drive. and various usb stuff.
I've got the m10000, 7TS and a bu-353 gps. I think there would be alot of people with _very_ similar setups to what you are using. Even if they have to add a driver or two for more peripherals, I think that it would still be a great base that alot of people would benefit from. It may not quite be a 12 second cold boot, but I bet it would be a hell of a lot better than what alot of people are getting at the moment
The part i sell is the white .063" aluminum chassis + lid and harddrive mount. You will need to drill & tap your own holes where you want to add hardware. The chassis I sell is a starting point to the fabrication. Its by no means a turnkey solution for all your hardware, rather a solid chassis to mount all your hardware as necessary for your build. If you are ok using a drill and basic hand tools you will be fine. Either way aluminum is pretty easy to work with. I use 6/32 machine screws on my entire chassis so I only had to buy one tap.
I will share the ISO if you are interested. I know this is kind of abut if someone has the space ill FTP upload it.
so this case is a double din u said. so its possible to bolt in dash? do u have a picture so I can get happy?
Read the whole thread and look at the pictures. There must be over 20 pics of the chassis in this thread, some pics of the actual production model and various autocad pics of the unit that have dimensions. Also look at sonic v8's thread, he purchased a chassis from me and has pictures of his build. Link is also in this thread. This chassis is designed to bolt up to OEM aftermarket trim kits like the metra series.
