Page 21 of 78 FirstFirst ... 11121314151617181920212223242526272829303171 ... LastLast
Results 201 to 210 of 778
Thread: Complete bolt in Screen/CPU/HD/PS - indash
  1. #201
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by deadbolt View Post
    Excellent leading edge work. Your system looks OEM. Wish I had a double-din. Am I mistaken thinking without that bezel an 8" screen might fit? Hard to tell from the pictures.
    Any thoughts on having the flash easily accessible so you can do updates from your desktop ?
    On this semi-embedded OS, what happens if you plug in a new USB device the system has never used before. I guess what I am asking is how is the plug-and-play affected with the write filtering ?
    Thank you for the compliments! I don't think the 8" screen will work. The flash module is easily removable if I pull the PC. It only takes 15 minutes and 10 screws to pull the whole unit out.
    The OS is a true embedded setup. Im not sure what you mean by semi-embedded. It will still detect USB devices like flash drives, keyboards, input devices, etc. If I want to make changes to the volume I can turn off the EWF (enhanced write filter) and commit all changes ive made to the OS by command prompting:
    ewfmgr -commitanddisable -live
    When I am happy with what I did then I run:
    ewfmgr -enable
    and it turns the write filter back on next boot.
    The USB plug and Play has nothing to to with EWF. This is an OS module than can be removed but I kept it intact in my OS image.
  2. #202
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thank you for your chassis order deepsky! Looked at my paypal this morning. I will have this complete and shipped out this week.
  3. #203
    Sep 2003
    So you are selling these now? What exactly comes for 65 bucks?
    Nogaro 2000 Audi S4 (Stage 3)
    Black 2000 Audi S4 (Stage 1)
  4. #204
    Jul 2005
    Motorcity
    Blog Entries
    1
    The white aluminum chassis part of my build including the top plate. It is for Double Din and is not ford specific. Any after market trim kit for Double Din can use this chassis. I will try to post up a pic later on tonight of the unit that im making right now for deepsky.
  5. #205
    Newbie mangina24's Avatar
    Feb 2004
    Looks great, good job.
  6. #206
    Jul 2005
    Motorcity
    Blog Entries
    1
    Here is your chassis deepsky. Still need to drill and tap some holes for the top plate. Hope everyone has a great Xmas filled with carPC presents.
  7. #207
    Sep 2003
    Quote Originally Posted by blk02si View Post
    Oh man that is NICE. So what would you charge to install an LCD if I brought you one? There is no chance I have the means to take one apart and put it in there nice as you did.
  8. #208
    Jul 2005
    Motorcity
    Blog Entries
    1
    Deepsky i shipped your chassis out. Emailed you the tracking #.
    I could make the chassis, disassemble and mount the screen into a trim kit and assemble the whole shot, ready for bolt in for $150 (you provide the 7" screen)
  9. #209
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    ewfmgr -enable
    U said that u have limited writing on the system disk because too much writing from the OS will nuke the flash card... what about suspension? u have 512Mb RAM.. when u suspend your system XP will wrtite at least 400MB of stuff on your disk, isn't it?
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  10. #210
    Aug 2004
    Faenza, Italy
    Quote Originally Posted by NiSlo View Post
    I've got the m10000, 7TS and a bu-353 gps. I think there would be alot of people with _very_ similar setups to what you are using. Even if they have to add a driver or two for more peripherals, I think that it would still be a great base that alot of people would benefit from. It may not quite be a 12 second cold boot, but I bet it would be a hell of a lot better than what alot of people are getting at the moment
    i have exactly your hardware... can u share the iso so i can try it? I think my license will go with this one aswell... mine too is an XP pro...
    Hardware:
    Software:
  1. indash touchscreen vga rca inputs
    By mike86ttype in forum Classified Archive
    Last Post: 01-30-2005, 10:30 PM
  2. FS: Indash Unit from tm-701L
    By BoraXP in forum Classified Archive
    Last Post: 01-15-2005, 03:48 PM
  3. Cheap indash monitor
    By darkhavoq in forum LCD/Display
    Last Post: 11-21-2004, 03:01 PM
  4. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 09:15 PM
  5. Nissan Sentra 1996 GXE Complete Project. 14'' Screen
    By criterzzz in forum Show off your project
    Last Post: 08-01-2004, 01:07 AM
