Page 22 of 78 FirstFirst ... 12131415161718192021222324252627282930313272 ... LastLast
Results 211 to 220 of 778
Thread: Complete bolt in Screen/CPU/HD/PS - indash
  1. #211
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I don't suspend my system, I do hard offs. I was thinking about implementing hibernate, but i would have to get rid of the GPS maps on the flash to make this possible. Right now my cold boot is fast enough for me to not need to hibernate. If you would like to try my XP image PM Nislo. He has it up his FTP server. Post back with your results.
  2. #212
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    How much do you charge for custom work?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
  3. #213
    Jul 2005
    Motorcity
    Blog Entries
    1
    it all depends on the complexity of the work and how much time and materials I use. For a custom aluminum enclosure, built to specs starts around 100$
  4. #214
    Nov 2005
    UK
    Hiya, I've read through most of this thread, but i've got one question.
    when playing music etc, how do you get it to carry on from where you left off? or cant you?
    i mean, every time you boot, does it not try to play the same song?
    I'm loving what you've done by the way, both the fab work and the software. excelent job.
  5. #215
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well the OS boots to the same state every time, so yes it is always on the first track when i start. I have my frontend load with random enabled and autostart music disabled. So basically I hit the "next" button and then hit play and I have my random song. There are a few limitations to using an embedded os but the advantages outweigh the limitations for an automotive application. So far the OS is running great and very responsive. GPS app is much faster and more accurate running from flash also. It seems to update faster. Also since i did the embedded OS I took the power scheme away from my ignition controlling it and just have a hard on-off switch now. This way I can just leave it on if im just stopping in somewhere for 15 minues or whatever and just leave it on. Also I don't need my keys to turn it on. When Im done using it i just hit the switch and it does a hard off. (the switch also controls my amp remotes)
  6. #216
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thank you for the order ras22_b! Bent your chassis today at work and will have it shipped shortly.
    Im also working on a 'chrome' edition chassis. I built this for me but its an .063" unfinished aluminum chassis that has been buffed out so the metal is a satin finish. It has a really hardcore tech-e look to it. Although the epoxy finished aluminum looks really clean, this buffed metal looks show worthy. May begin another bolt in PC with this one, 'chrome' edition, only best of the best parts in a mini ITX form factor.
    Will have pictures of both up soon
  7. #217
    Sep 2003
    Talking
    Quote Originally Posted by blk02si View Post
    This is probably a stupid question but is anyone going to see it when it's installed? Or is the front part where the monitor goes have a chrome surround you can see? Guess the pictures will explain.
    Nogaro 2000 Audi S4 (Stage 3)
    Black 2000 Audi S4 (Stage 1)
  8. #218
    Jul 2005
    Motorcity
    Blog Entries
    1
    Nope no one will see it. Except the owner when bolting the PCB's to it. I've built so many of the white chassis that I thought I would try something new with the unfinished. Plus I had a perfect size scrap to bend one up. I buffed it out with fine steel wool and was impressed by the finish. painted chassis is probably still a better way to go but just wanted to try something new. This is a pic before I started buffing. The chassis on the left is yours ras22_b.
  9. #219
    Dec 2006
    can't wait to get started on my project!
  10. #220
    Mar 2004
    Wonderful install!! It looks beautiful.
    I wish I could do something like this, but I have a ScionXB. The Metra kit for this xB doesnt look like it would be friendly to this project
    Here is the kit if anyone wants to give their opinion if it would work or not:
    Click Here
    As you can see, its only the sides.. Its not a full, rectangular kit.
  1. indash touchscreen vga rca inputs
    By mike86ttype in forum Classified Archive
    Last Post: 01-30-2005, 10:30 PM
  2. FS: Indash Unit from tm-701L
    By BoraXP in forum Classified Archive
    Last Post: 01-15-2005, 03:48 PM
  3. Cheap indash monitor
    By darkhavoq in forum LCD/Display
    Last Post: 11-21-2004, 03:01 PM
  4. FS: Complete Mini-ITX CarPC w/Xenarc Monitor + More
    By DLe in forum Classified Archive
    Last Post: 10-19-2004, 09:15 PM
  5. Nissan Sentra 1996 GXE Complete Project. 14'' Screen
    By criterzzz in forum Show off your project
    Last Post: 08-01-2004, 01:07 AM
